APOCALYPSE Sega System 16B Multi Sales, Installation and Support
Thanks, I could download it but how do you install it ? I downloaded and unzipped it. And I have a file topall_ver8, it is different than version 8.36
I am not sure but I would guess the installer_x64.exe in the driver folder will install the drivers, and after that, the topall.exe will probably run from the folder after you double click it
If I am trying to open the installer_64x, something tried to open but directly shutdown
I can’t open the installer_64x.exe. If I double click on it something is trying to open but directly close it.
The drivers seems to be installed, I am not sur if it s correct one. When in tried to open the software topall8.36, the following message pop up and when I click ok, it shutdown the software
That exact same thing happens to me when I launch the topall software and the device is not powered on + plugged into the pc usb port. Did you hear the windows notification when you plugged in the top programmer device (with the power switch on)?
Plug with the power switch on ? I hear some sound from windows when I powered it after plug in. Ok I will try to power it and then plug it. Then what did you do ? You open the soft ?
By the way, I can’t open the driver install.exe file. When I double click it seems to open but then directly shutdown
Is it the same version of the driver (topall013) that you used ?
I tried your idea, but always the same message pops : only support modal: ….
I think this top3000 will flight to the trash
Topall013 in Devices manager when its on and connected by usb. The Topall software, that I have installed, has an update drop down and it goes here! I actaully have the install disc with the box, do you have that too? Here is the link to the software update http://pan.baidu.com/s/1hqJdtpq
I have this too in the device manager, when the usb is connected with the programmer on libusb …. And topall013 appeared. I don’t have the disc I am trying to get the last version of the software from the seller but for some reason he doesn’t want to sent it to me. All the link I have lead me to Chinese pages I can’t read. I don’t understand why I cannot open the installer x64 exe for driver installation in the file you sent me the link. When I double click, it open then shutdown. Is there a windows security or something that bloc the file opening ?
Honestly because the above should be a self help thread in a different category about how to use a cheap chinese programmer and not in here about system 16.....seriously.
Buy a t56....
Create a thread about top3000.
Does SDI work on the system 16B single
Trackball I/O?
Because I bought a trackball I/O and I KNOW it is a system 16A game and have the multi 16B. And am wondering what is required to get it running for single player....hence the thread.
Buy a t56....
Trackball I/O?
I did nt know it would be so long. Sorry
