DARKSOFT Games Fixed to work with DIMM
Hey no worries, I’m trying on NetBoot. I think it’s a atomiswave game that’s been ported.
Just wanted to see if it starts for someone else using wipi? My sd may be corrupted or something but all other games load.
Cheers
Hmm I started it (Capcom I/O) and same, just a black screen . Left it here for awhile. Test buttons don't bring up the menu. Normally if it's an I/O prob it gives you a message about that. I'm on 15 kHz atm but same, if that's the prob it usually tells you
Thank you. It’s a multibios. I’ve tried other random BIOS, and same results.
https://imgur.com/a/iUVMQBY
Multibios is not good for many games, specially conversions. Try a stock BIOS. It was somewhere explained which one to use.
Capcom I/O is known to be power hungry and not good with Naomi. I would try another I/O
thanks same result as me. maybe it never worked on netboot?
cheers
This conversion was done checked and known to work for many years AFAIR.
Oh I should clarify, i use a Sun to power the Naomi and the cab with the I/O when I netboot.
It's true though on this particular cab the 12v is low. All other games I've tried boot fine but I'll try another cab to verity Bass Fishing
Thank you again. Wanted to clarify that I have also tried HotD2 with the stock Japan H bios, and the results are the same. Consensus seems to be that Japan H bios appears to have the best compatibillity, but I have also tried some several other Naomi 1 BIOS I have lying around (I will make a list when able). The result is the same.
EDIT:
Also tried BIOS: D-21577, 21330 (HOTD2 stock bios).
For completeness, I have also tried these multiBIOS (which I think are the same or very similar):
" p1pkin multi region bios"
"Proper bootsrap"
Unfortunately, I do not have much computer knowledge. But, I believe the problem is easily reproducible. If there is interest in looking deeper, and in making a better HotD2 bootable file, that would be amazing. Thank you again.
I received from an anonymous source a link to a working version of Virtual On.
He will try to have a look at some other non fixed games. Be sure to keep an eye to this thread.
NEW ADDITION!
Wolrd Series 99: https://www.mediafire.com/file/yulvqghnpge97gj/smlg99_converted_CF.7z/file
Ninja Assault (NJA2 World ver): https://mega.nz/file/Md0lFZrY#qxbP4FZ1t5gu0anX2vlsxH1dmkXrFiGlPSPYP_HvhHM
House of the Dead 2 (HOTD2): https://mega.nz/#!JEszHYhT!ZXwEKkOM-NLTp0p6hs923u4A1B9WAgo_qxTKdUw2VMo
House of the dead 2 prototype (based on existing fixed hotd2): https://archive.org/details/hotd2p
--> Differences with regular version explained here: https://www.arcade-projects.com/thr...-prototype-on-a-real-naomi.26994/#post-394968
Puyo Pop Fever game (world/english version of japanese Puyo Puyo Fever): https://mega.nz/file/QY9UGCzC#S-NdD_Jol7nae1YY3c8MRwRPxq3pTueQDX2axQ_bcoA
Virtual On Oratorio Tangra: http://www.mediafire.com/ download/b2iarrtqusfhf96/ vonot.7z
Gun Survivor 2 (Fixed to not require COM Board): https://mega.nz/#!dcslEKDB!5IXbfHloGVWQiizeDR_533gd9C1-CT4P-SHAPKmsX2o Works with 512MB DIMM
Out triggers: https://mega.nz/#!1R81WQyI!Lmo89SP4wIMFUgRHXKbdUx6vsTRSps9uxt_oAoYRMW8
Tokyo Bus: http://www.mediafire.com/download/18oarkwv46a6ep3/tokyobus.7z
Wild Riders: http://www.mediafire.com/download/grhf7p0rbrp2rhh/wldrider.7z
Rhythm Tengoku: https://mega.nz/#!REtjGYiR!0tHXYR9G7yUpzDnkxBGxey61SHCB7R49J7YVdgPQhYQ Works with 512MB DIMM
Prowrestling Toukon Retsuden 4: https://mega.nz/#!gMdB3Y7B!yEVkjCljpHw9ftgaCOyIAJvDu1AXPcT0uxULl1VdJTg Not Working yet.
Marvel vs Capcom 2 USA: http://www.mediafire.com/download/gq1354aez6xycsk/mvsc2_epr-23062a_hack.7z
Capcom vs SNK 2 Mark Of The Millennium 2001 (Latest version): http://www.mediafire.com/file/549gqqme7lau4un/Capcom_vs_SNK_2_Mark_Of_The_Millennium_2001.7z
Shootout Pool: http://www.mediafire.com/file/iiux94wfgldeezv/shootout_pool_epr23844_v2.7z
Guilty Gear: http://www.mediafire.com/file/odl9iiau0eo44f1/ggx_v2p.7z
Crackin' DJ hack: https://mega.nz/#!ddUSFCja!9pMf6fkRn-AavCF6l8yTFNjFREKcBI2_Qrcy-1ZGxw4
Note: It requires rotary 13938 IO, and DJs turntable to play.
Japan Mushikings 2K4 2nd and 2K5 1st:
https://mega.nz/#!MQNDCbpY!oiXwiqFYX-coZrc9SO5VqiXeNWLEQReELoJbgBia9UM
https://mega.nz/#!kFFAWZ5R!dY19fsChjKqWBPI4x5uG7AnPMUe8vWr-38PFZFXoy9c
SPECIAL BIOS BY P1PKIN:
Here is Christmas gift to community: modded Naomi/Naomi2 BIOS with region switching. It's in the tools folder.
https://mega.nz/#F!lg4TTIrL!Bs03RF6fYjoUg1YYUt70Dw
Use DIPSW 2-3 on filterboard to:
Code: Select all
DSW2 DSW3
OFF OFF Japan
ON OFF USA
OFF ON Export
ON ON Korea
Gakman's Naomi/Chihiro/Triforce Rom Depository!!: https://mega.nz/#F!lg4TTIrL!Bs03RF6fYjoUg1YYUt70Dw!14JgBSJK
It appears that the *Puyo Pop Fever* archive is password-protected.
Could you please let me know what the password is?
requesting a netboot rom for touch de uno or any touchscreen-based game since I am trying to confirm a touchscreen I bought works. I have all of the necessary hardware.
which exactly touch game you need? Naomi games uses at least 3 different touch screens / its controllers - Touch de uno 1/2, Manic panic ghosts and Touch de zunou, Starhorse.
This is just out of personal interest, but would it be possible to create a patch that allows games which normally only run at 31kHz—such as *Rhythm Tengoku*, *Airline Pilots*, and *Sega Strike Fighter*—to run at 15kHz?
