mR_CaESaR
Yeah I figured it out. Thanks. I'm just using the hole on the case instead of rerouting through the jamma edge fingerboard
@Mitsurugi-w where does this wire go?Are you able to shed any light on that extra wire needed for slam master? Thanks!
Thanks a lot, that solved the issueHi,
I had a similar issue, just look at this video:View: https://youtu.be/7ouwKRqkoag?si=luqisvWYBSz8D-tW&t=632
There is a switch in the Darksoft board that you may need to change.
At least that solved the issue (I use a HAS supergun too).
Hope it works!
Front outside of the case. The case was designed with the white connector holes lining up with the soldered pins of the joystick connectors in a certain way; since my unit has the white connectors holes offset by a bit (possibly due to the above theory), the PCB doesn't line up well with the case and the joystick ports soldered pins hit the plastic instead of going through the case holes that were made for them (marked red).Is that picture the outside of the case or the inside?
