BOUNTY for Taito G-Net CF Conversions.
If programming was my specialty....alas.
it's a pretty unique set of skills.
I know lots of amazing programmers who wouldn't be able to do this.
essentially you have to reverse engineer how this all works
A good analogy would be if programmers were book authors, able to write amazing stories.
But doing a conversion is a bit like an archeologists who needs to decode, and then translate an unknown language, then make some adjustments to the wording before translating it back. - A very different skill set than writing a book.
Any new interest in this?
Is there a definitive list of what has already been done?
ZN has been moving along very quickly...
Basically, the Gnet will be "out of date" very soon i think.
It will still be great for games that use the taito sound chips, but for everything else there will be a more fancy solutions coming out (probably in some years) :)
It seems a week does not go by without more ZN findings / developments!
The memory card port has been figured out, but needs testing.
There has also been a development with the bios boards that should get the install down to less wires yet again....
Running homebrew / PS1 software will probably be figured out within the next 6 months and then a PSIO type thing will follow for loading games.
And probably a capcom multi for the Q sound stuff, so everything is covered.
(maybe PS1 "qsound" games such as ALPHA3, Warriors of fate ETC, could be ported / modified to use real Qsound too!)
@Darksoft , is it not time to merge the G net , Capcom and other ZN topics into it's on section to keep it all in one place? <PS1 based arcade HW>
At the moment it's spread out over many sections... and they are all basically the same PCB.
Perhaps the future combination can have an unpopulated spot for the taito sound ics.
What is the likely requirement for donor boards for any potential multis? ZN2 for ZN games? Taito board for Taito games?...etc? :)
Okay, thanks for the bumps to the thread to get me to come back to this. I started working on the final 8 likely conversions a few months ago, and I finally got back to it, finished them out, and tested them on my G-Net hardware tonight.
Conversions completed:
  • 1 on 1 Government (TPS BIOS)
  • Dead Or Alive ++ (TPS BIOS)
  • Gallop Racer 2 (TPS BIOS)
  • Gallop Racer 3 (TPS BIOS)
  • Logic Pro Adventure (TPS BIOS)
  • Monster Farm Jump (TPS BIOS)
  • Tecmo World Cup Millennium (TPS BIOS)
  • Tondemo Crisis (TPS BIOS)
https://drive.google.com/drive/folders/1NLAoPO-s4LCNvB4XO5yoHFswxy-t1erN?usp=drive_link
Both .img and .chd files at the link. You can use the .chd files like the other ones with the G-Net Flashing Software from ikotsu, or you can just flash the .img files using Win32DiskImager or your preferred program. The same CF rules apply as the other conversions; make sure you are using working cards, Sandisk 64MB-2GB. I tried an 8GB card and it wouldn't work, but my 64MB ones are just fine. Please let me know if you run into any issues, I tested each game on a fresh flash but obviously I can't play each for hours before releasing.
I understand that some of those pledges were from a very long time ago and that times and circumstances change. If you are still willing to pay out the pledges I really appreciate it, but understood if it is not possible and absolutely no hard feelings. EDITING TO MAKE IT COMPLETELY CLEAR THAT I AM NOT EXPECTING OR HOPING FOR BOUNTIES FROM ANYONE, ANYTHING IS APPRECIATED BUT THERE ARE ZERO EXPECTATIONS. CONSIDER THE @ 's BELOW AS A HEADS UP THAT THE PROJECTS HAVE BEEN COMPLETED AND THAT YOU SHOULD PLAY THESE COOL GAMES. Mostly, I just want people to enjoy these games (especially Logic Pro Adventure and Tondemo Crisis, what gems).
@twistedsymphony @rewrite @Darksoft @ekorz @jugu @suverman @Brentradio @theoddtech @CoinFeeder @ShootTheCore @Tietscha @9999 Damage
Bounties can be sent to [email protected] via PayPal with no expectations, truly appreciate y'all and hope you enjoy the games.
Also, if there is an appetite for further conversions please let me know what you are interested in. I was considering doing research on porting Brave Blade's music from the Yamaha chip to the native chip to see if it is even possible to get music going directly on the G-Net, could be fun.
Lastly, someone needs to get on making new stickers for the CF cards :D
Quick question regarding FX-1B conversions if I may.
I've noticed that G-Darius suffers from quite some slowdown especially if you rapidfire @30Hz.
Now since the G-Net is "the same"as FX-1B but beefed up in CPU clock frequency (some other things maybe too?) this game should run with less slowdown, right?
Or would the game force the CPU to run at 33MHz instead of 50MHz?
