Yeah, im gonna clean it up and do test prints. These are to label my ssds.I like the one with the 'Intel' multi-inside logo the best
Might as well also engrave acrylic drive covers for the x2.
Had something similar after swapping to the new 2.0 image on a SSD. Reimaged like 5 times but in the end it was something more basic. I pulled the Taito out of the cabinet and redid every connection, reseated memory, checked cables for sharp bends everything. After which it got put back together and it worked (with every disk I threw at it).Having an issue with my taito x2 if I have the I/O unplugged I get the cannot find I/O message. With it plugged in it gets to boot window then crashes to black screen. Is this a video card problem or should I try to reimage the SDD? Maybe something got messed up? Before this the fmv was slowing down/freezing. My best guess is a video card.. thanks for any input
tried with capcom io and sega io
The multi looks for a "game.exe" file on the root of the thumb drive, if it doesnt find one it will throw that error.I've tried running MAME through a USB stick formatted in FAT32, but no matter what I've tried with the file structure, I keep getting an error on the X2 saying no USB is detected.
Any ideas what the structure should look like on root? I've tried following the directions on the first post, but no luck.
I've also read several topics on here that say contradictory things about MAME working through USB, so if I'm chasing something that doesn't work, let me know that too.
Definitely a SSD issue tried to reimage swapped them out with a known working board same thing. SSD was brand new worked for a few hours.. guess I’ll pick up another not sure formatting and reimaging will help? Should have stuck with Samsung hate HP crap..You might try a different SSD/HDD just to rule that out. Also ensure the SATA cable and power cable are fully and securely attached to the drive and motherboard.
Typically when the graphics card goes out, you'll get some artifacting and or windows BSOD.
That's the general consensus I have heard for TTX2 games as well. From my own experience happy with the P4 and TTX2 games. I haven't tried mame or adding any other games outside of TTX2 stuff so can't comment on that.Why the CPU upgrade? My assumption is the P4 is still the fastest single thread CPU and the other supported dual/quad CPU’s have slower single cores.
From what I know TTX stuff runs on a single core so more a step back I would say.
Unless someone can convince me otherwise or correct me of course
