Nope.Basically what I wanted to do was get the system to play Chase HQ 2, Wacky Races, and Battle Gear 4, all in my Chase HQ 2 cab. Is this possible?
I don't know how common it is, but on my X2 the dip switches were covered by a piece of black plastic that had to be removed.For those of us with X2's without dip switches, will menu resolution also be an option within the GUI?
It is possible completely just requires effort and timeNopeBasically what I wanted to do was get the system to play Chase HQ 2, Wacky Races, and Battle Gear 4, all in my Chase HQ 2 cab. Is this possible?
There is a completely is a solution for it using nikos jvs to keyboad and coreys fast io to keyboard. You bind both to keys ( no true analog support )or you recompile this code to support a jotstick commandOf course. There just isn't a solution for it at the moment and I don't think anyone is working on one.
No way niko you mean all the tools where out there it just takes someone to care enought to put it together almost like my 4 post said it 2 amazing!By design, the multi will launch any game following the correct folder layout on the games partition of the multi.
If all of those driving games work with the same I/O board(s) in your cab then it will work, otherwise someone would need to write a wrapper/emulator for the needed I/O board.
Don't know if I understand well what you said Niko but don't think the multi can actually launch all game.By design, the multi will launch any game following the correct folder layout on the games partition of the multi.
I choose to use "launch" over "run" for that specific reason. lolThank you for your great work on the multi Niko!!
Like some curious I try to launch some nesica games and following of course the correct folder layout on the games partition of the multi but results are black screen and return to the menu for many games like Akai for example or Persona (with the correct crypted key)
The only one I succeed to launch is BlazBlue Central Fiction and got an io error.
i have looked at this a few times. due to the specs and windows xp this does cause frame drop and lag using the tools on the internet for this.@atrfate and niko = Will it be possible to run a shooting game on a horizontal screen, maybe an option to choose between vertical and horizontal with arts on the sides ?
IMO if this is easy to remove a game you should let all them so everybody can custom there multi with the games they are interested in.
