I picked the current resin relatively randomly to have a starting point to work from. Transparency would be nice, but coloured opaque should work as well.https://www.smooth-on.com/products/task-9/
Only downside is the short pot life, have to work fast. Excellent resin for what you trying to do, assuming transparency is a must
Seconded.On-topic question, was the ddp white label from the glue master guy ever dumped & released?
TOP3000 can with a SOP to DIP adapter.Hi guys,
This is not a PGM specific question, but I believe people in this thread will know.
I'm repairing a PGM title now, and need to burn a MX26L6420 to replace a broken w064 ROM.
But, I could not find a good programmer that supports MX26L6420.
fyi, I have a TL866 and a TOP3000 now. So, if I can write MX26L6420 by them with a sort of adapter, that's better.
I'm using it because it is better than nothing... I'm not good enough to do a full loop, so I'm most likely not going to hit it for a while.Thats the version w/ the crash in it.![]()
http://www.arcademodbios.com/ supposedly makes it but I think you have to specially request it. Plus then it's covered in hot glue.Where can you buy the undumped dualboot cartridge?
Oh, really?! I already have a SOP to DIP adapter.TOP3000 can with a SOP to DIP adapter.
Nope. I had the Ketsui which was lost then found. But he did offer to make me one just before the conversions became more common place.@djsheep - do you have one of these?has anyone actually confirmed that the AMB one doesn't have the same issues as the ones we've tried here?
Humm, am I mistaken with my other programmer? Let me check that.Oh, really?! I already have a SOP to DIP adapter.
Which programming software do you use?
I'm using Topall Ver8.37(2018-04-24), but it does not have the MX26L6420 or similar device name in the "Select chip" menu.
