Posted on a couple different forums with less than stellar response, so I'm hoping maybe someone on here has a DM/Pop'n/GF/something and has experienced similar issues.
My cab's overlaying the game picture with the software/hardware/device ID's and refuses to let you push start. Start works in the test menu, so I know it's not an issue with the cabinet. I'm assuming that the ID window is the "focus" and the game behind it isn't receiving inputs, if that makes sense.
Anyone seen this before? Ideas on getting rid of it?
http://imgur.com/eEpFa4f
Things I know:
Start button works in the I/O test menu. Actually, everything works in the I/O test menu aside from the red drum (I cut the wire reinstalling the 4 left drums).
It won't start in either Free Play or paid play modes.
Won't start in Game Mode or Event Mode.
HDD passes ROM check.
eAmusement is turned off via Dipswitch (anyone know what the other 2 dips do? I know 4 changes resolution).
I've tried with eAmusement both on or off in settings. Network is turned off at present, though I did try leaving it on and running an ethernet cable across the house.
Software, Device, and Hardware ID's stay floating on top of everything all the time:
Things I know:
