chriszhxi
HK
I'm using m4x10 tap screws on the hinge, screws can be tightened, but they will leave tiny space so that when open up hinge can move back and forth, is it designed this way or the height of screw is wrong or something wrong with the cab?
These are self tapping screws unlike the machine screws with captive washers on the versus/net city, etc.
They should work but perhaps there are shavings/crap inside existing threads causing them to not bottom out. I would try and clean/blow out the holes first. If that does not work then you could try adding washers or using shorter self rappers. You just want to make sure the hinge still closes without binding against the other side of the hinge on the CP housing.
