Atomiswave us attempting conversion
Narcissifish
usa
Rummaging around in somebody's storage unit while a friend picked up a cab
Found an atomiswave, extreme hunting tucked in the back,
Moniter, totally burnt was first to go
Working on converting to a fighting panel
But couldn't find a fighting panel
Work in progress
Guess I got to make a control panel
Nice!
Yes, it seems the joystick panel for this cabinet is quite rare!
The overlay would be in demand i think if you had a good scan done for it.
Hunting is actually really good game when you get into it! At least by making a second panel it's possible to swap back.
Ranger mission also works well with the shotguns , worth grabbing it's quite cheap.
I don't think i've seen that "elite stage" top sticker before either, on mine has a "pump to reload" one taken from one of the older wing shooting games.
After a quick search it seems not too common
Perhaps I can get it off with out damage then
Hoping to find a scan of the metal slug 6 kit for the cab
Time to make the donuts
Or I needed some wire harnesses, so made some
Having not done this before, not sure if correct
Where in the US are you located? I have a cab with Dirty Pigskin Football and fighting game layout panels.
Wire fun times
Not done, side tracked with other projects
Buttons wired
Added some artificial flavored "fancy" t-molding
And put the whole thing together
Only thing left is to get some art works for the insert and a new marquee ,
Also should power it on at some point
And it lives again
Kept the old hunting stuff around just in case
And need to get a new marquee
But for now it's good
Great job! I love these cabs, my only complaint it that you can to cut up a marquee to make it fit inside the weird shaped holder.
