AWSD Power Supply Interface PCB
I am curious about this too , how is the Power Supply mounted ?
The power supply was mounted in the most difficult possible way unfortunately. I unscrewed the wood board and mounted the power supply with screws up from the bottom, then reinstalled the wood board. I was hoping someone would eventually make a 3D printed mount that the power supply could snap into. Maybe if I get a 3D printer I will cobble something together.
Thanks for the heads up , it looks clean .
Tried to get a couple of these but didn't get a response so I went off and ordered the parts. Here's a dump of the information that I gathered while doing this, hopefully it is useful to someone.
https://github.com/wifiber/AWSD-PS-Interface - Github link which is really everything you need. Take a look at the readme.md file. It contains links to the V5 board and presumably any future updates as well. 3 of the boards are $26.
Actual part numbers from the parts.txt file for the connectors -
LCD Voltage Readout
https://www.aliexpress.com/i/32840259666.html?spm=2114.12057483.0.0.206f62fepYHKGu
J1 - Molex MiniFit JR 2x4 0039290083 (gold) 0039281083 (tin)
J3 - Molex MiniFit JR 2x6 0039290123 (gold) 0039281123 (tin)
J4 - JST B5P-VH-FB-B(LF)(SN)
SW1 - C&K OS102011MA1QN1
https://github.com/wifiber/AWSD-PS-Interface/blob/master/parts.txt
Mouser link for the 8 pin connector (2x4)
https://www.mouser.com/ProductDetail/Molex/39-28-1083?qs=orQbfqMgxgWE1Pu2XYbwgg==
Mouser link for the 12 pin connector (2x6)
https://www.mouser.com/ProductDetail/Molex/39-28-1123?qs=EaMIwIL37xzCyl5w6av%2BuA==
Mouser link for the C&K switch
https://www.mouser.com/ProductDetail/CK/OS102011MA1QN1?qs=WtljUlYws5R6MUgHcLkz4w==
JST / GAM-GEC.com link for the JST connector
https://gam-gec.com/product/bh5p-vh-1/
I skipped the LCD readout.
Sorry about that, I saw you reached out and should have responded. My bench is not really accessible at the moment, so I am pausing on building these for a bit. Looks like you were able to source the parts so hopefully you got all setup. I think @Lemony Vengeance did a batch as well, so that might be another option.
Reactions: Rix
The data sheet for the Mean Well QP-150-3A shows optional mounting feet. Searching around, it looks like the part number is MHS012.
I have a bunch that will be ready once the voltmeters get here :)
Did a quick and easy mount using the stock Wei-Ya bracket. I flipped it around so I could adjust the voltage pots from the left side.
Use M4X5mm or 6mm screws so you don’t hit the bottom of the power supply pcb inside.
I ended getting these feet. The good news is they’re very cheap. The not so good is that they’re meant to be installed with the power supply in horizontal position… I didn’t realize this until I got them 😅
I ended just bending them so the feet themselves were flat instead of L-shaped. Here’s the results when installed.
4AAFBC07-0BB6-48BE-A614-777014A3B3DD.jpeg26206B61-07F3-435E-89AA-7B170E4C4DFC.jpeg6F7869D5-C5DB-47D6-9713-FCCEA0A6EA60.jpeg
BTW, the interface works like a charm! Great job!!
Fans arrived, did a little more cutting on the case to removed the internal/lame-airflow restricting grill.
Hi everyone!
Sorry to derail this thread, but would you know if there is any chance I can internally swap out the fan for a ‎GELID SILENT 6 FN-SX06-38 ?
thanks a lot for any pointers :)
Edit : tested, and too thick to fit inside as is.
Wondering if someone can help me real quick,
I tried to install the voltage meter and switch on the pcb. When i power on i get 0.00 reading.
Not sure if i wire it wrong or maybe i have to solder in Jp2 and Jp3 in the back?
