Axun
China
I have ordered some samples from Z-JAMMA, two styles for soldering and PCB mounting. After I receive the samples and confirm the actual performance, I will sort out the product classification. Z-JAMMA and HRS-JAMMA options will be added.
I have been using Taiwan FUTURE, it may be a bit tight. But I think it is similar to HRS. There is also a tighter one in China, which has left a shadow on me.
The sales volume of Z-JAMMA products starts at 500PCS. So I need to confirm the sample first. If it works well, 500PCS is no problem. I will also use it for a long time
As for HRS. Because it is imported from Japan, the price is expensive, and it needs to be ordered to get the goods. So I can only guarantee some quantity. At present, I have ordered the HRS plug of 50PCS.
Finally, there is also a Japan NDK/TAT (light bite), in order to improve compatibility, I did not use it directly. Instead, make it an adapter.
Japan NDK/TAT (light bite):
The card slot is Japanese NDK/TAT Noguchi, and the contact terminals are pure copper-plated gold, light bite and stable transmission, suitable for frequent replacement of substrates, and easy and smooth disassembly and assembly.
If your JAMMA is tight but often replace the substrate, you can install it to change the replacement efficiency and prevent accidents.
Joko3
Yokohama, Japan
Would it be possible to change an existing order with the HRS piece? Order SQ202106106175295526. Just ordered everything this morning.
Axun
China
The HRS special buckle to prevent misalignment or reverse insertion, it seems to be discontinued. So that kind of gadgets are not available for the time being. If the KEY notch is welded directly, it may affect the compatibility of different JAMMAs. For example, some DIY JAMMA has no notch
Joko3
Yokohama, Japan
OK, I have written it down and wait for the actual update of the product category. I will contact you by email to make up the difference. Thanks for your support!
Thank you very much. I sent a message on the website about this as well, but I accidentally ordered a JVS power and data cable that I don't need (I ordered the JAMMA only supergun). Please let me know if this can be taken into account when calculating the price difference. Looking forward to this supergun : D
Axun
China
OK. If you do not need the JVS cable, I will note it in the order and will deduct it from the final price difference.
djsheep
Multi Boyz Overlord
Multi Boyz
Brisbane, Australia
You can 3D print the JAMMA keys here: https://www.thingiverse.com/thing:3770398
klee123
Brisbane
I was thinking maybe offer the option for the extension cable as well since when I do order mine I'll most likely will only connect my PCBs to the supergun via extension cable.
