Here’s proof of the Darkness Illusion working on the AxunWorkVampire Savior has a problem when performing luminous illusion with Lilith, and Darkness Illusion with Morrigan. If button 4 is connected via the JAMMA edge and the kick, you will not be able to perform the move despite inputting the correct button combo.
The way to test would be to pick lilith, get your special meter up to at least 1, then do: LP LP FORWARD LK HP quickly.
Doing it correctly will result in a special move. Doing it incorrectly, or with the JAMMA button 4 connected, you will stand there like an idiot doing normal moves.
AMAZING! You are on track to sell a must own! I still want to order one, but I want to wait for the improvements!@bktrunks the Undamned USB decoders will solve your Neo-geo input situation![]()
as you can see in @dannahan post he has a pair, as do I they are great! and Undamned makes legendary stuff
@xtrasmiley We do intend in getting USB inputs added. This is a hope by next year.
and I am sure black PCB is possible.
YES, GREAT idea! Some sort of built in adjustable analog controls would be amazing. I'm not sure how different games handle this, but maybe since this is used a lot with Naomi, start with that?If you could integrate some analog support such as use usb wheels with brake and gas pots to play initial d, crazy taxi etc. that would be nice
