RepairGuy95
Cps3 cart shells?
Agreed on all points. I don't have a resin printer that uses lasers and pre-heats, I just have an Elegoo Saturn Ultra 4 which is just about as basic of an SLA printer as you can get. Works nice for what I use it for, but that's also not business.Yeah I really don't know how Formlabs is to work with on used machines, or how reliable they are in general. I'm always been leery of their lock-in ecosystem, but I just print in normal ass resin, nothing fancy. For an actual 'business' use I think they're super interesting. Buying into their resin system is just the cost of doing business.
Thank you so much, I'll be sure to start pouring over them soon. Bummed about the industrial machine not being worth the extra right now, and I hope to find some sort of solution in the 5 ounce range down the road, but just over 2.7 should do for a lot of stuff. Hopefully find enough work to pay myself back for the machinery and then I can consider how to go bigger after that.Thanks! Just let me know. Regardless of what type or scale of machine, I strongly recommend having these books as references:
These are absolutely a reasonable size if memory serves.Cps3 cart shells?
This stupid POS makes me so anxious on both of my exceleenas....
Granted, it's a wild endeavor to make a replacement.
One can dream
Sick, I just looked out of curiosity, glad it was helpful. Also, uh, if you just search for "form 3L" on eBay you will get some pretty good results that I will not post here.I reached out to that seller on eBay and we're going to figure out a time to meet this weekend. Thanks for pointing them out! With all the extras it's a solid deal for sure.
I really don't know what I put in the other night, but only the top and bottom ones here came up at the time:Also, uh, if you just search for "form 3L" on eBay you will get some pretty good results that I will not post here.
Yeah I've had a few chats with my buddies that do metal work, pretty feasible to do but you'd lose a lot of detail/curve if you go that route.Okay, hear me out. Because no one is ever going to get a run of these done with a mold, it's just way way too big/costly for a DIY endeavor, and I'm sure bonkers expensive to get a real company to retool to make a run of these. But it's small enough and lacks many details, I'd be surprised if you couldn't mill it, yeah?
I did! And this is why some things only make sense in the DIY space. Time doesn't matter if you're not a business. Plus, quality CNCs at home are cheap now. PrintNC can be built in the standard 23x35 bed size for right around $1800. Pick up a few jobs, pays for itself, now you have a free tool that can make any and everything your heart desires (until your heart gets too big and then you need to upgrade).As far as milling it, assuming you mean like CNC the machine time alone would make it obscenely expensive
Folks seem to suggest these have been superseded by this design here and that using the L brackets at all is no longer "in".2. DDR sensor L-Bracket Spacers
These books rule. I "found" them, and also grabbed a physical copy of the second one through the library lending program. Fascinating so far.These principles apply to basically anything injection molding related, whether it's an industrial machine or benchtop press.
Yeah, that's what I'm being told, that even arcades running cabs are moving over to this other method. Ah well. Was a cool idea.DDR pad modding is kinda in flux right now. FSRs have gotten more popular somewhat recently which will affect the sensor area quite a bit. You'll probably see FSRs more often on custom/DIY pads, but I imagine a fair amount of real arcade pads will begin to get FSR replacements as well.
Oh that's an awesome idea (and incredibly easy since datasheets have dimensions). I didn't think of that but it makes sense! I reached out a bit back to that one French harness seller if they could make an E29 one, but they said some connectors were just no longer available but they could reuse mine and make a new harness.No longer produced connector housings would be cool too.
You didn't find the easter egg apparently. Censored for public consumption lol.I really don't know what I put in the other night, but only the top and bottom ones here came up at the time:
Yeah you better blur it, some on here are delicate flowers.You didn't find the easter egg apparently. Censored for public consumption lol.
