Does anyone know what this is for on the New Net City Audio Amp?
Kinda looks like a black RCA? Im looking at the wiring diagram but not understanding it.
Oh man this is what I assumed, wish I knew this before my mishap lol. Ty!I think it might be an un-amplified subwoofer output:
https://www.arcade-projects.com/threads/subwoofer-on-sega-cabinet.7514/
I bought the VF3 marquee above, but it came with a smaller version too. Does anyone know what it’s for? Advertising or a different cab?
I need to check if a I have the amp.Do you need an amp? I ended up with like 4 spares.
For the VGA cable, it may be worth having a look with the connector shells off. Mine had some wires that broke free on one end as the jacketing had pulled away from the stress relief. You could also pin it out with a meter, but it is just about the same amount of effort and you can meter it with the shell off much easier.
If you do end up needing a VGA cable, look for cheap sega/naomi wiring on ebay. I bought an entire lot of the video, audio and power connectors for something like $30 shipped. I can help you look if needed. Certainly do not pay a grip for a new cable from whomever.
Good luck.
The wiring loom you bought, one end plugs into the Model 3 stack, and the other end plugs into the Blast City I/O.I purchased this VF3 Blast City Wiring Harness -> https://buyee.jp/item/yahoo/auction...aSGZGQ2JYRW00eWFVL2R4OVVpVVlBZG8vekVUdGxjQT0=
I bought this for my Sun Power Supply ->
I see though in pics with VF3 all setup it looks like 4 power connectors instead of the 3 that my Sun PSU has? Not sure if I need another power connector or not?
The Stock Blast City PSU I am hoping powers whatever is missing?
I tried to research but kinda overwhelmed by all the connectors.
I don’t need an additional power supply other than the blast city stock one?The wiring loom you bought, one end plugs into the Model 3 stack, and the other end plugs into the Blast City I/O.
You should get both sound and video with that wiring loom.
The Sun PSU doesn't connect to your Model 3 loom.
If your Blast City PSU is in 100% working order, it will power the VF3 stack just fine.I don’t need an additional power supply other than the blast city stock one?
I thought I’d connect 3.3v and 5v from Sun PSU to power Virtua fighter 3 and use the blast city stock psu to power the cabinet.
Or you mean don’t connect Sun psu to loom but to model 3 stack?
I haven’t received the loom yet will probably take a bit from YAJ. Thank you!If your Blast City PSU is in 100% working order, it will power the VF3 stack just fine.
You will need to check the voltages, there's an adjustment pot on the Blast PSU.
Did you actually try and connect the Model 3 loom to the Sun PSU?
You will find that the connectors are different and they wont plug into each other.
I've added a picture to the above post.
That's how I used to power my SpikeOut FE stack before I made a custom loom to use a Lindbergh PSU.
If your blast has a Jamma loom already installed, take that out and plug the Model 3 loom in.
DSB2, SoikeOut FE uses it to play the music.What is this board?
