CoolFox
The AD-65 is a "bootleg" Oki M6295U8 is a ATF1508AS-10AC100.What is the chip code on the atmel? More than likely secured up anyway like the first one.
The smaller U18 quad just has the text AD-65 on it.
I received the ROM board without a mainboard and just stuck it on a stock ZN-1. I didn't even connect the two wires. Maybe the issues with the game came from that?
Dumps of the two other socketed roms can be found here:
https://www.sendspace.com/file/jza92e
I have no way of dumping the MX chip. I can remove it if someone wants to dump it.
The link is dead, does anyone still have a copy?*** EDIT *** Yes roms are modified.
Run through romcmp 2 vs. 9 files:
Code:at27c010.bin 1111xxxxxxxxxxxxx = 0xFF br2_u0412.412 1xxxxxxxxxxxxxxxxxx = 0xFF br2_u049.049 1xxxxxxxxxxxxxxxxxx = 0xFF rom-2b.210 1ST AND 2ND HALF IDENTICAL at27c010.bin br2_u0412.412 [3/4] 95.651245% at27c010.bin br2_u049.049 [3/4] 95.651245% at27c010.bin br2_u0412.412 [4/4] 95.651245% at27c010.bin br2_u049.049 [4/4] 95.651245% 27C160.bin [2/4] flash0.021 [odd 1/2] 5.271530% 27C160.bin [3/4] flash1.024 [odd 1/2] 4.819298% 27C160.bin [4/4] flash0.021 [odd 2/2] 3.338814% 27C160.bin [1/4] flash1.024 [even 1/2] 2.874374% rom-1a.028 NO MATCH rom-1b.29 NO MATCH rom-2a.026 NO MATCH rom-2b.210 NO MATCH rom-3.336 NO MATCH
What are the marking on the chips ic353 (bios) & ic652 (cat702) on the motherboard?I received the ROM board without a mainboard and just stuck it on a stock ZN-1. I didn't even connect the two wires. Maybe the issues with the game came from that?
That is a shame, I have a reasonable idea how the protection works on these bootlegs but I can't see how it could work on any motherboard. In fact I can't make it work on the motherboard I'd expect it to work with either.No clue. I have long since sold the motherboard and I'm left with just the cart.
Only two of the bloody roar 2 roms are dumped. One of the ROMs is for the OKI & the other is for the CAT702 replacement.The motherboard must of came / got sold with a game, whatever original software worked on there should give an idea.
Is all the program data dumped for this bootleg then? one of the dumped roms looks like for the OKI.
Do you have the g-net conversions booting in mame yet?
You could cross your fingers for luck and buy somedo you have any info on how to make a repo protection chip? I've heard that before but I haven't been able to find any info other than the mame driver.
Thanks for the detailed explanation! No wonder was a bit baffled by the dumps.. No program LOLOnly two of the bloody roar 2 roms are dumped. One of the ROMs is for the OKI & the other is for the CAT702 replacement.
The CPLD appears to just grab a byte from the ROM and bit shift it out. Only a small part of the game boot is encrypted and so a replay attack is practical. The beasorizer bootleg that is already in MAME has a similar ROM, oddly they used a 16 bit EPROM and the upper and lower bytes of each word are identical.
The file seems to include the responses from the CAT702 on the motherboard and the one on the gameboard.
However after 0x50 bytes, this dump and the one from beastorizer diverge from what MAME normally returns and the game crashes. This might be an emulation issue that eventually fixes itself (the bios retries accesses if it gets data it doesn't like, so it might not be working properly anyway) or it might be that the CPLD does something more complex than just shifting each byte out from the start of the ROM to the end.
Raizing would of had access to the real original sound chips, it's gotta be a bootleg due to the lower quality OKI being used.I can't currently see how either game would boot on anything other than a raizing motherboard with ET01 CAT702 and -54 BIOS. It's possible they found some way of exploiting the bios & I'm missing some crucial part of making it work.
Which does raise the question what game they were using as the donor, as we don't have any other games dumped for this motherboard at all. It's possible that raizing knocked out the bootlegs themselves, to avoid paying Sony some licence fee. If Sony supplies the CAT702 programmed, then it's an easy way of enforcing some form of per game license fee. All they had to do was order a few hundred motherboards as spares.
This is clear now, there's a much better wayI don't see any point in trying to duplicate it for making other bootlegs, now we know how the CAT702 works then adding an extra ROM is more complex. In fact it's the mask roms that is the biggest hurdle.
Haha, a lot to say here but let's just say no comment for this one... Other than the big surprise he has any friends leftI've thought about supporting the g-net conversions in MAME, however someone on DU is friends with arcademodbios and so it's currently on hold. I don't tend to speculate on things I might do in the future, to avoid over committing myself.
The output from both of the cat702 chips are wired together, but when they aren't active the outputs float. If they just captured the data on the output pin, then they would get the output from both cat702. My guess is the outputs get AND'd so as long as the bootleg is outputting what the motherboard cat702 outputs, then it's fine. If the cat702 replacement is always active then you might be able to remove the cat702 from the motherboard and still boot.Raizing would of had access to the real original sound chips, it's gotta be a bootleg due to the lower quality OKI being used.I guess the 2 wires going to the bottom board feed the game with the ET01 data, but as you say it does not explain the bios lock...
Click the empty box in the upper-left when typing a reply to see the bbcode version which is easier to edit.smf said:This message board is annoying, is there a way to switch it into a mode where you can easily copy and paste the quotes?
doh, thanks. how did I miss that.Click the empty box in the upper-left when typing a reply to see the bbcode version which is easier to edit.smf said:This message board is annoying, is there a way to switch it into a mode where you can easily copy and paste the quotes?
It's a different Bust A Move 2. In countries where Puzzle Bobble was released as Bust A Move, they released the other Bust A Move as Bust A Groove.I'll add $10 per game as well for most, and $50 for any of the 3 'viable' games (bloody roar, nba jam, puzzle bobble 2)
