Mobiusstriptech
Up for sale are the citrus3000psi RGB boards for the Colecovision/ADAM. These boards are designed to be soldered to the bottom of the VDP and provide RGBS to an output connector of your choice.
To properly calibrate these boards, 3 onboard POTs are used to adjust each color individually.
Please note that to properly calibrate the board, you MUST use an oscilloscope. If you do not calibrate with an oscilloscope and choose to adjust by eye, please note that any compatibility issues, damage, or world ending results via the summoning of Cthulu are solely your responsibility.
Each kit is sold as a DIY and fully assembled/tested before shipping. If you receive a board and have issues, please contact me. If the issues are found to be related to misuse or improper installation, you are on your own. If there appears to be a defect in manufacturing, I will work with you towards an amicable resolution.
No output connectors are provided, except with install service. Output connectors can be whatever you wish but the cables themselves must be pass-through, ie no capacitors or resistors installed. If you need assistance with purchasing cables or output connectors please reach out and I can answer your questions.
Each board is $30 shipped in the Continental US (CONUS).
International shipping available for $10 extra
If you do not feel confident with the installation or would prefer to have it installed for you, I will be providing install services with oscilloscope calibration of the board.
Cost of this service is $80 including the board, but not including return shipping.
