Looking forward to testing this. My setups are ready!
I'm afraid I don't understand what you are asking. Can you clarify?I have one NNC like you and Jammafier. What's use external power supply or via JAMMA? It's seems cant use external power supply withit. And Can I use hack pad via JVS
JAMMA only. Keep RCA output audio at line level to be controlled in the cab's amp.Quick question for all interested parties. In the current design the volume pot controls both JAMMA and stereo RCA out. Is this preferable to most users or would it be better to have the volume pot only control JAMMA audio and leave the RCAs as line out?
Thanks for letting me know. Do I need to worry about loading the 12v rail? I'm not using it for anything at this time. As for the 5v rail I assume 1 amp of load would be sufficient to work with most power supplies?One more thing - this PCB won't load enough many arcade PSUs. As a fix, you could add a spot for a cement resistor.
I now have them listed in my store. The price includes shipping to the continental USA.What's the best way to order a couple of those MC Cthulhu boards? I have 2 of them but I really want that RJ45 connector default!
(also lol, this account I'm posting from isn't my own, I logged out and logged into my own account and now I'm back as "NeoXbit". I can't make it stop)
1A will be enough. Make sure you first test that resistor before producing larger PCB quantities, since it's right under the P1 board. 10W can get extremely hot (hopefully the large ground plane will help dissipate that heat).Due to the suggestion of @RGB I've also added a load resistor on the 5v rail to help stabilize some arcade PSUs. I chose an SMD metal film resistor that has a thermal pad to help dissipate heat into the ground plane. I opted for this approach instead of a cement resistor due to size constraints. The resistor value may change, in my research about arcade PSUs it seems like 1 amp of load should be enough to stabilize the 5v rail on most PSUs, but if I can get away with a lesser load I would prefer that. Opinions on this would be appreciated.
You can buy the chip from Paradise Arcade:Nice work![]()
So for the EZ Cthulhu I need to harvest the chip from the original correct? There is no replacement for this part (yet)?
Wouldn't hurt anything if you did and is a great idea.
- I have added a header for Player 1/2 Home and Select so you can wire additional buttons for Home and Select to your control panel. Should I also add pins on the header for P4 and K4 buttons for those who have 8 button control panels in their cabinets.
CPS2 in a landslide for the ubiquity of cabs out there that use CPS2 kick harness. CPS1 or other style connector only if foot print space on your PCB is at a premium. Not the case with your design however.
- Is the CPS2 kick harness the preferred option, or would it be better to have a CPS1 style kick harness connector and use adapters for CPS2 and other kick harness types. The CPS1 connector would save space on the board and make more room for an expanded auxiliary button harness. Also it seems like CPS1 is one of the easiest harness types to get adapters for.
