xodaraP
Legendary
I'm going to say a case for a consolized MVS
This is very fast.I'm going to say a case for a consolized MVS
I Will share the project soonNeo geo case? Where do I pay? please take my money...
Enjoy with it.Finally got mine installed. I still need to hook up the LED lighting, which I'll do later when I can get a moment away from the holiday family stuff.
But here's how the red looks with my Third Strike cart. Ironman red ftw!![]()
Thank you for posting these, as I too have a 5.0 SCSI2SD and a short cable so knowing this was possible makes me happy. I gotta say the clearance (or lack thereof) between the caps on the SCSI2SD and the solder on the SIMM slots makes me a little nervous though.I put mine together today and am loving it!
First I soldered a molex power connector to the other end of the power wires for the LED:
This way nothing has to be soldered onto the CPS3 board while assembling and it can plug right into the motherboard (since the SCSI2SD doesn't need power via molex and can run straight from SCSI cable alone).
Next I moved the mounting board for the SCSI2SD towards the back of the case. This was required to work with my short SCSI cable which I've been using with my previous plexi setup.
It works fine and mounts perfectly with the older SCSI2SD revision!![]()
All put together:
It's fantastic! I really like how it can optionally mount in cabinets too, as that's where this will be spending the majority of its time.![]()
Ditto on the (just barely) not touching, so we should be good.No problemo, yeah there isn't much clearance between the top of the capacitors on the SCSI2SD and the CPS3 motherboard but in my case it didn't seem to touch the legs/solder on any components (though just barely).
What feet are you referring to? The mounting rails attach to the side of the metal case then those get screwed down to your wooden PCB board in your cab.
You don’t need to remove the rubber feet. It screws down just fine, but it’s not flush with the wood if that matters. Check itDitto on the (just barely) not touching, so we should be good.
I'm referring to the feet on the bottom of the case, it almost seems like the rails wouldn't go down far enough, if that makes sense? And it's going in a Big Blue, so no boards for me, straight attached to the side of the cabinetNot that that makes any difference really...
Can you please share with me your payment mail , name,address and tracking number.@hursit have the metal cases sent out for any australia buyers yet? I am still waiting for mine to arrive
Hello,Finally got my case together, pretty nice. Only problem is I think my mounting holes were slightly off. The fifth mounting hole by one of the chips for example where the pcb screws in can't be screwed in. The four corners were slightly off too but I managed. Is it meant to be like that?
I still don't see how you can have a default SCSI cable all in there (15-18 inches). I folded mine quite a bit and even under the SCSI2SD mounting plate and I don't see how. Any tips on how?
Also be careful screwing in the mounting holes for the cps3 motherboard. The standoffs are small enough that if you apply enough torque it can get stuck in the hole. Two of mine on the left side did that andI barely tightened it. Easy way to fix that would be to make thicker mounts
