FOUND CPS1.5 mounting feet
Item has been found
Did you have an interested in non-original but functional ones? I was in need of a set and have been curious about metal fab/bending with sendcutsend.com and took a stab at making replacement ones. The silver ones are from sendcutsend and the goldish ones are original.
Forum isn't letting me upload this picture
https://www.mvs-scans.com/misc/IMG_1566-1.JPG
They had some manufacture limitations so I couldn't get an exact replica.
  • They won't do 2 bends that close together so the replica's leg is about 2mm taller
  • Because the part was so small they wouldn't countersink the screw hole or apply a coating
I only needed 4, but there were price breaks based on quantity ordered. 1 to 9 was around $12 each, 10 to 49 was around $6 each and 50+ was around $3.5 each. So I ended up getting 12 made. You are welcome to a set if you cover cost ($24) + shipping.
Thank you again @ack. I'll still leave this up in case anyone finds an original set they no longer need.
Reactions: ack
Thank you!
Should have a deal, so marking this closed.
