What would I need to check? Sorry for all the questions, Im a real novice at this so dont really have much of a clue.But if you can't get to the test menu with C8 set to ON, there must be a real hardware problem. You have to check the A-Board.
a board is - 89626A-4 (battery not removed)
and even trying the test button on my Supergun (not a cab mind you), I get no test menu.
But just to confirm - C8 turned on, no test menu,
You're welcomeSorry for the double post, but I think? I've fixed the issue. I think it was bad contacts on the dip switches, as after some finessing, both the difficulty and continue options now work. I'm still not 100% clear on what happened (I feel the underlining issue might still be eluding me), but after trying some more SF2 and 3 Wonders, I can now continue. I wont be so much as breathing on these dip switches from here on out, out of fear something will happen!
Thanks again for all the tips Roch![]()
I downloaded the Pendragon set, which isn't prepared, is just the zip files, and doesn't unzip to a games folder. I can't find a prepared multipack on archive.org. Please could someone PM me a link as we aren't allowed to talk about this top secret multipack here?If you downloaded a general mame set you have the wrong files, look for the prepared multipacks. Same overall data just arranged and concatenated to work, plus extra files to control the lcd, dash and qsound functions
My fault most likely. I neglected to remove when soldering near the dupont connectors.SD card fried?
Only SDHC work, the smaller size, the better. I recommend specially Samsung or Sandisk, but they must be from a trusted source, there is a lot of counterfeit around.
I always use 32gb's, sometimes I will format the FAT32 partition smaller however (depending on the size needed) and I always adjust the cluster size (to 64k).The 32gb should be good.
Maybe someone close to you in New Orleans has one that can lend for you to test, but I'd go for another microSD first.
If you put the old B board back on now, is it fine still?I am wondering why the original ROM board didn't have issue with this A board.
