dreday12203
Exactly... I don't either. It is running mono and was recorded with a handicam FWIW.Frizzle I don't really hear any crackle in yours unless I'm missing it..
Every one I have personally tested (4 or 5) has some form of crackling. Some are noticeable and some you really have to strain to hear. It is a strange issue. Personally, when I am playing a game I don't really notice the crackle. It can also be slightly negated by adjusting the volume on the cab and the pcb but it's still going to be there. But I know that a lot of collector's are really anal about these things so I really do understand the annoyance.A lot of games use only one sound rom. Those will give you no crackling. Apparently the crackling only happens when the QSOUND DSP chip is reading from the two flashroms at the same time. (It doesn't read from both at the same time, but it does read from either on very short time intervals)
also having the crackling audio problems over here. using an xmen: children of the atom donor board, rev 6 with a G PAL from darksoft and no jumper wire. everything else functions great.Every one I have personally tested (4 or 5) has some form of crackling. Some are noticeable and some you really have to strain to hear. It is a strange issue. Personally, when I am playing a game I don't really notice the crackle. It can also be slightly negated by adjusting the volume on the cab and the pcb but it's still going to be there. But I know that a lot of collector's are really anal about these things so I really do understand the annoyance.A lot of games use only one sound rom. Those will give you no crackling. Apparently the crackling only happens when the QSOUND DSP chip is reading from the two flashroms at the same time. (It doesn't read from both at the same time, but it does read from either on very short time intervals)
My question now is if there is a way to mod these kits or are we looking at a potential redesign for future potential runs. Maybe a larger flash for the sound?
We're working on the easiest option for a fix. As soon as we are sure where exactly the problem comes from, we'll post all possible solutions we can come with (firmware upgrade, adding resistors, etc)also having the crackling audio problems over here. using an xmen: children of the atom donor board, rev 6 with a G PAL from darksoft and no jumper wire. everything else functions great.Every one I have personally tested (4 or 5) has some form of crackling. Some are noticeable and some you really have to strain to hear. It is a strange issue. Personally, when I am playing a game I don't really notice the crackle. It can also be slightly negated by adjusting the volume on the cab and the pcb but it's still going to be there. But I know that a lot of collector's are really anal about these things so I really do understand the annoyance.My question now is if there is a way to mod these kits or are we looking at a potential redesign for future potential runs. Maybe a larger flash for the sound?A lot of games use only one sound rom. Those will give you no crackling. Apparently the crackling only happens when the QSOUND DSP chip is reading from the two flashroms at the same time. (It doesn't read from both at the same time, but it does read from either on very short time intervals)
the problem is more than just an annoyance, for me.
please keep us updated on a potential fix.
At this moment testing is leading us to explore options on the main kit pcb as a potential fix.So can anyone confirm if there are any B boards that don't cause the sound crackling issue, or is it present in all revisions?
Around second 40 when it says "Welcome to the..." it's when you here it quite clear.Here's a good example of the crackling sound:
