Can confirm this on the two kits I have here.the presence or absence of the LCD doesn't affect the issue.
ME too! Those chips are so tinyExcellent news, fingers crossed for an easy applicable solution for the "normal" knowledged user!![]()
This is the cable I ordered from Ebay... I've never used the multi without the LCD screen attached, so I couldn't say.Actually jassin000 , what happens if you unplug the LCD altogether? I might try this tonight if I get a chance.
Also, whats the ebay link for that rainbow cable - wouldnt mind keeping that handy
it's more due to dozens of chips being in close proximity to each other and stray electrical signals interfering with the normal operation because the chips are sensitive. setting the 5V at 5.0000000 won't help.Would a different/better power supply help? Or fixing the Aboard to deliver perfect 5V?
Are you saying the Spaniard has no rhythm? Blasphemous!It zigs but the zag is missing!
AFAIK that's the reason why they do it, so that all signals traverse the same amount of mm of copper. This is also the reason why they changed the hard disks from ATA (parallel) to SATA (Serial). The speed was so high that a very small desync of one bit and you get an error...and with so many billions of bits going through, the higher the speed, the higher the probability of data loss. With serial, you don't have that problem, one bit at a timeThe major reason for zigzag-ing traces on high speed buses is make it so all signals (in a bus) reach the chip at the same time (make so all signals have to traverse the same distance in coppper). Another stuffs like capacitance and induction are considered when deciding where each trace will go to. As Guru mentioned.
That's another way of fixing it, but takes a guru to solder thereno crackles here. mine is working just fine
What do you mean?So...is it confirmed that the fix developed by Mr T Guru works perfectly? with all games? if it does, I think that should be the implemented fix, as opposite to waiting for the custom boards that Darksoft will order and make him not spend more money, shouldn't it?
Thanks!!
