mastercello
Jeremy, maybe you should add which exact Pin it is, because it is not clearly visible in your picture!
Thought I had mentioned it. It's B21 of that connector. Edited last post.Jeremy, maybe you should add which exact Pin it is, because it is not clearly visible in your picture!
The reason why the removal of the sound test timer was criticized is obvious. It make Phoenix menu sound test feature a pretty moot point.Criticism is the reason we opened these forums. More freedom for all of us. Release what you want.![]()
If what happens here doesn't stay here then it's not your fault.![]()
Phoenix roms aren't all bad. If it wasn't for the Phoenix roms this forum wouldn't exist. lol.The reason why the removal of the sound test timer was criticized is obvious. It make Phoenix menu sound test feature a pretty moot point.
I was not commenting of the "Phoenix roms" in particular. I was simply commenting on how anything made to improve the situation of the free romsets would cause negative reactions from the other party providing decrypted games.Phoenix roms aren't all bad. If it wasn't for the Phoenix roms this forum wouldn't exist. lol.The reason why the removal of the sound test timer was criticized is obvious. It make Phoenix menu sound test feature a pretty moot point.
I have to put that quote in my signaturePhoenix roms aren't all bad. If it wasn't for the Phoenix roms this forum wouldn't exist. lol.
Do it.I have to put that quote in my signature
The latest Avalaunch set has them included. If you add other games yourself the easiest thing to do is copy a name file from another game and edit it with notepad.What is the best way to apply Spectre's name files, or are they already renamed correctly in the latest 150531 set?
Great, thanks. Is that the only game that's missing files?The latest Avalaunch set has them included. If you add other games yourself the easiest thing to do is copy a name file from another game and edit it with notepad.
Also notice that in the latest Avalaunch set Marvel Super Heroes USA is missing all files except .02 so you need to copy them from the other available set.
I honestly have not loaded every single game in that set but I think that the rest are all there.Great, thanks. Is that the only game that's missing files?
This is my version using CN9 with re-using a connector commonly found on a Sega wiring harnessAdded this picture to the first post. Anyone without the CN9 connector can add their auto-reset wire to B21 of this connector like so:
Welcome Guru and thanks for your support.This is my version using CN9 with re-using a connector commonly found on a Sega wiring harnessAdded this picture to the first post. Anyone without the CN9 connector can add their auto-reset wire to B21 of this connector like so:
