zero238
I'm still down for a full set.
Hmmm, I guess I'll take your advice then... Since I've only got the one CPS2 I'll just leave the Tournie stuff to you guys.but If I were you I'd just get a new B Board and wouldnt get into messing with that
You aren't wrong at all. In fact, SSF2 was the only game to use the network board.SSF2 is the only CPS2 game with tournament mode; am I wrong?
We hope to change that.You aren't wrong at all. In fact, SSF2 was the only game to use the network board.
If you could somehow make the link work over a TCP/IP tunnel and put a RJ45 jack on the PCB, that would really be awesome!We hope to change that.
It should work fine if you add the connector. And since you only need to remove solder from the holes instead of a connector it should only take a few minutes to do. Just a normal right-angle connector like this should work fine:Hmmm, I guess I'll take your advice then... Since I've only got the one CPS2 I'll just leave the Tournie stuff to you guys.but If I were you I'd just get a new B Board and wouldnt get into messing with that
If it wouldn't add a ton in shipping I'd offer to put the connector on for youI'll pass, its a really cool project tho and I'm glad you guys decided to go forward with.![]()
