SubScorpion
Just checked and it's pretty steady at 5.3, which I guess is a little high but everything works fine other than the occasional solid color screen freeze in the pic above. It doesn't do it often, just once in a while and like I said is usually fine after I turn it off and back on again.What are your voltages at? Try bumping it up a bit to 5.10 at the edge and report back after a while.
What is measured at the JAMMA edge or by a voltmeter isn’t necessarily indicative of what chips are receiving on the board.
I toned it down to where I'm getting 5.5 at the edge connector and I'll report back of the issue persists.I’d drop your voltage down to 5.1v max. 5.3 is way too high and could be the cause of your issues or have damaged some components on either your CPS-2 hardware or multi itself.
