So I've had the luck to find a CRT locally with a Blast City Tube, Model A68KZN696X, and I'm pretty sure that the Tube is compatible with the Chassis I bought, the Sanwa KW0606A.
So this would be my first attempt at an Arcade setup, so as a starter I don't really have the basics of cross tube compatibility. From what I've researched, the New Net City uses a flat microfilter Tube by Toshiba, as much as I'd like to see that in action I'd be happy trying out my curved Tube.
So I wanted to confirm that I can use the Blast City Tube, Model A68KZN696X with my KW0606A, as long as I can find a matching Yoke. Is this correct?
The info below shows a similar Tube to mine, but, I'd guess my Yoke may have different requirements. Is there a method to figure out that type of info, or just research on the webs?
There's a MS-2930 yoke for the A68KZN696X on Yaton's website, I'd buy it but not sure if the KW0606A requires a different yoke.
https://yatonarcade.com/products/to...yQrkIc1gClZbExWhOMMohdduiwk9Q2PJOmc4PHKCzPhTI
