jermz1
went to lowes today.
Rubber Grommet
Rubber Grommet
what does your cabinet have inside as far as volume controls?Can someone advise me how I would connect these? I am running a PS4 and PC in my cabinet... confused how I would connect the wires to the buttons.. sorry wood worker not electrician here!
You my friend are in for a world of pain. I have been dealing with this conundrum since I got my vewlix in 2014. The problems are tenfold. For example, you first have to deal with just having the PC work correctly. See, PC's don't assign USB's statically, meaning every time you turn on the PC your 1P and 2P controls might be switched depending on the PC's mood. There are "fixes" for this but it goes into a rabbit hole of hobby made drivers and what not. Currently I am reworking my new PC I built for my MAME cabinet and am trying to solve this issue once and for all.I currently have the Cabinet being build and sent to me, my plan was just to set up some speakers from the PC and some how connect to PS4 as well? I am guessing the volume control for them can only be connected to either the PC or the PS4 at one time.
I guess my real question is, How do people connect but panel/control sticks panels to work for a desktop AND Ps4 without having to constantly switch the USB depending on which one I want to play.....
Was waiting until the panel audio issue was sorted out. I'll have to read up on the solution.Moving to Korea by the end of the month.
If you plan on placing an order, please do so soon before my stuff gets packed on the 24th.
its not done yet
close to finish.ugh, the links don't transfer in quotation.Components needed for panel.
4 - M4-.70x10 Metric Pan Phillips Machine (screws)
4 - M4-.70 Nuts
6 - 30mm buttons
2 - USB MOUNT
1 - Volume Knob
1 - Volume Controller Must remove housing.
1 - Rubber Grommet
I'm interested in this! Do you still have to remove the housing from the volume control? Will this be available soon?finally got a step drill, I can countersink the hole now to rid the need for a grommet
