Pr3tty F1y
Absolutely. That looks like a fantastic recommendation. Thank you!If you allow me a tip, on next installations use Kynar cable
I'm trying to convert a Gals S2 (Rom-4 board) into Cyvern following the instructions.
Everything was fine until this screen where the game seems to bé stuck into.
Did I miss something ?
The opposing, lifted, corner pins (i.e,. PIN1 and PIN23) on the surface mounted SOP44 roms all should be connected back to the 3.3V power source.I wonder if anybody could give me some pointers on a Sengeki Striker conversion? I purchased this from somebody on this forum, but I'm unfortunately missing a background layer on at least level 1 (the holes in the top layer are just black, but there should be ground in them). Here are some pictures of the PCB:
The MX chip (just below NEP-16 silkscreen) in the first pic - it doesn't seem to be connected to anything, but there's a wire connecting two pins on the chip itself. This doesn't seem right to me. Any help would be much appreciated. Thanks so much!
I created a ROM 3 BOARD Cyvern a couple of weeks ago after my dumb ass soldered the ROM chips upside down on the rear of the PCB, de-soldered them, re-soldered them upside down AGAIN, de-soldered them AGAIN, and then finally re-soldered them the right way. I could blame it on being tired, but I'm also quite stupid (as it is apparent from my actions).Hey all, does anybody have pictures of a Cyvern conversion on a rom 3 board?
I gave this a shot yesterday, and I get past bios, but the game doesn't load.
You are correct. I'm juggling so many PCBs that I'm losing track (hence why I need to get my notes in order before doing a more formal assessment). My Sengeki Striker is ROM 4 board. Someone in this thread (maybe it was you?Sengeki Striker uses a 7th graphic ram which is inside the custom ROM-3-BOARD and ROM-4-BOARD bring installed. Sure you are going to have graphic glitches
I tried that convert in the past in a ROM-2-BOARD and the test says this:
That VIEW3 CG error is related with a 7th graphic ram which is added on ROM-3-BOARD and ROM-4-BOARD.
On MAME driver, says that ram is used for tilemap decoding, because Sengeki Striker uses 4x32mbit sprites roms and 3x32mbit tiles roms: 7 rams needed.
So, the chip at U8 - I notice there's nothing there on Nebula's cart, but mine has a chip there. Mine is a JP Jan Jan Paradise 2 as well, fwiw. Do you simply remove the rom at U8?I created a ROM 3 BOARD Cyvern a couple of weeks ago after my dumb ass soldered the ROM chips upside down on the rear of the PCB, de-soldered them, re-soldered them upside down AGAIN, de-soldered them AGAIN, and then finally re-soldered them the right way. I could blame it on being tired, but I'm also quite stupid (as it is apparent from my actions).
Anyway, I followed the images posted by Nebula here: https://www.arcade-projects.com/threads/cyvern-conversion.5886/post-163710
I didn't take any pictures of my work so I don't have anything to show, but I played through the first full loop and it worked/played fine.
I need to take some time to post my findings here, but I'm thinking that there may be some security issues with the Lattice chip on the main board next to the BIOS rom and the PALs/custom chip on ROM 3/4 boards that interact. I'm strongly suspecting that the cartridge PCBs maybe be semi region locked (I'm thinking that it may only be Japan region vs. every one else, but that's just a guess).
My ROM 3 board Cyvern was from a Japanese (white cartridge) Jan Jan Paradise 2 and it worked fine on a Japanese board with the Japanese Mod/Universal BIOS.
However, and I'll eventually get around to making a larger post about this, I made a Sengeki Striker on a ROM 4 board from an Asia (green cartridge) Puzz Loop ROM 4 board. I actually didn't screw up making this one. It came out fabulously!BUT IT WOULDN'T WORK ON THE JAPANESE BOARD REGARDLESS OF THE BIOS.
So I pulled my USA main board out of storage and ran it with the Japanese Mod BIOS and Sengeki Striker would run but ONLY as the ASIA version. If I tried to use Japanese region 27C801 DIP32 ROMS for U4/U6, it wouldn't run.
The symptoms changed based on the board region and the BIOS used. The Mod BIOS could usually get the came to kick over to the in game check, but both Puzz Loop and Sengeki Striker gave a "Security Error". Using a non-Mod BIOS would just stall within the BIOS and it would repeat the "only for use in this region" screen.
I'll need to do some tests again to make sure I have all of my facts right, but to my amateur eyes, the only thing that looks like it could be a likely culprit for security on the main board is the Lattice CPLD. And I'm also suspecting that the PALs on ROM and ROM 2 Boards and large custom IC on ROM 3/4 Boards differ by region and are part of this lock and key mechanism. As far as way this only affects certain games - to me it could be region combinations that just work or some games just may not institute such checks (at least that's my running theory).
