D.I.Y. Universal ARCADE STICK (with DB15 connector)
Here's the stopper.
I hope it is the one you are looking for
https://ie.farnell.com/essentra-com...anceMax-High-Margin-Test1573&gross_price=true
The name brand is Heyco strain relief, there is a special plier to “unlock” it also…I have one somewhere I’ll see if I can find a name brand
https://www.heyco.com/Strain_Relief_Bushings/
@rewrite
I’d also recommend using a forstner bit to make the holes for the buttons and stick, it’ll be a cleaner hole. They come in all sizes.
5) JOYSTICK selection
6) BUTTON selection
7) DRILLING HOLES
8. WIRING
9) COMPONENTS INSTALLATION
10) DONE!
...continues to the following post
Hi, I have a question, where the +5V from DB15 is wired in the stick ?
Thanks
+5V is only required if you have some logic in your stick, like macros, remapping or auto-fire.
Thanks I don’t have a board, I plugged directly on button, ground and directions . I will try first without +5v
Hi,
+5v is pin 8 on the DB15 connector. Everything is wired to the NeoGeo Fighting Board. I hope I have answered to your question.
Thank you, I don’t have a neogeo board . I was wondering in a stick like sigma 8000TB, where the +5 V is plugged. Probably on the board, you are right
Ok it works, I have modded the Astro city mini arcade stick with a db15 wire.
Thanks everyone for your help
Introducing the board "HYPERDRIVE ARCADE", which will be listed next week.
This board is an arcade encoder using DB15 pins (also for Neogeo) that can be implemented on an 8-button joystick by modifying it.
It has a 4-button and 6-button remapping function, and when you press and hold the remap button, it makes a "BEEP" sound to enter the remapping mode. Press the A,B,C,D,E,F buttons in the order you want, and the piezo buzzer will sound in the order "DO, RE, MI, FA, SOL, LA" to finalize the setup.
There is also a terminal for WS2812B RGB LEDs, so you can also use the RGB buttons.
This works with DB15 (supergun/Cbox) and Neo Geo out of the box with no mods?
