Is that corrosive flux? I’ve never seen the residue be powder white
It looks like an effect of the light to me.How to I get the test romset?and not sure how to find 0xffffff onlyIt could be an issue with the multi but to me it looks more an issue with the B Board. Try that test romset and for now keep testing only games that the key file has values 0xFFFFFFF only.
Before loading a game, check the content of the file called "key" that is located inside the folder of that game. Open it with an hex editor and you will see only 0xFFFFFFHow to I get the test romset?and not sure how to find 0xffffff only
https://www.arcade-projects.com/threads/romset-to-verify-your-cps2-kit.11886/#post-191917How to I get the test romset?and not sure how to find 0xffffff only
You have to look at the LCD. It will say VERIFY OK or ERROR. I believe it will say VERIFY OK and the problem is in your setup somewhere else that we didnt think of yet.I'm a bit confused about test roms I loaded up the 2 folders 01010101 and 10101010 they both loaded up and I got a purple screen not sure I did this right.
There must be a problem with my other cps2 motherboard I tested it with a working game and only got black screenCan you try the test now with your other cps-2 motherboard. Also trying the games that work and don’t work to see if you get the same results?
Correct the motherboard connected to the multi works fine my other one does notNot yet. @jared mills has two CPS-2 motherboards. One working, and (as we just heard) one not.
No garbled graphics with this motherboard? If so nice to see that it got resolved.Correct the motherboard connected to the multi works fine my other one does not
I believe he has garbled video on the ‘good’ board with most games. Some games run ok though. The bad board is just black/purpleNo garbled graphics with this motherboard? If so nice to see that it got resolved.
CorrectI believe he has garbled video on the ‘good’ board with most games. Some games run ok though. The bad board is just black/purple
Can’t it also be the A or B board in that games that does not use all aspects of the board function but games utilising more have this problem?So is this a problem with the multi? Seem strange it plays a couple of games fine but the rest are garbled graphics. I'm running out of things to try
