but no drama, even when I openly talked with Razoola and ROT about my DS multicart purchase in chat.
Just kidding
Now please let's go back to topic.
This error is related to the menu. The 1st issue you reported I believe it's also related to the menu and should be fixed in the next release.In Metal Slug 1 - even after clearing the backup ram and the internal memory card contents, the high scores table shows all zeroes instead of the preset high scores like APE, BAT, etc.
Did you check the voltage on the Jamma edge? I assume you have the latest firmware.- Blazing Star (slot 1) has some graphical glitches in the intro. There seem to be one line of pixel jam at the top area of the screen...
https://drive.google.com/open?id=1YKRrvMFh9WNdIUz7Kgh-zfzC2a4InlnS
Yes, also if you insert a coin when in the menu. This will be fixed. It's a menu thing.Don't know if this is normal!?: I am able to reset the menu ONCE with the select button...
https://drive.google.com/open?id=11WmK1AOIvEqO-keECWizYIL_Bb5vf04e
Same as #1. Either your mobo isnt working properly, you dont have the latest firmware or you have a problem. If it's a power problem cutting the trace close to R193 would fix it. *IF* power turns to be the cause, it's an easy fix that you can do yourself or you can send it for fixing.UPDATE: I emptied all slots and changed my game setup to: (1) Blazing Star, (2) Metal Slug 3, (3) KOF 2003
it ended up with this freeze screen![]()
After switching off and on again, the menu showed all the 3 games in its slots.
I didn'T start any of those, emptied the slots an flashed again in a different order.
It worked, the procedure looked like this:
https://drive.google.com/open?id=1W8zcqLR_NOsXDqNfvNZGIz9fogBU0mHD
Same as above. Either a mobo or a power problem. Do you have another board to check? Can you check the power reaching your mobo?EDIT 2018-08-03:
Here is another video
https://drive.google.com/open?id=1dlYZE5Wam-yR7ymiplhk4hhj6CI5KGdp
In the first two parts you can see the white pixels while flashing. There's few of them but I had loads last time, when the Multi was running for some time.
The third part is showing that the buttons in AES mode won't work with Metal Slug 3 - when I set it to arcade mode, it works...
No. Those should not be missing. Try to reinstall them and clear the system's NV ram.I uploaded to the most recent firmware and menu but I do not see a bunch of games in the menu now. I do not see Blues Journey, Bomberman, Stakes Winners and others. I did delete the BUFF file and verified the games are still on the micro-SD card.
Are a bunch of games removed at this point?
Thanks!
Interesting... I don't have those but I'm using an OMEGA CMVS. Sounds like I should check the power on that jamma edge?this could happen if you had some type.of HAS or 6-in-1 boards to connect multiple jamma boards.
Did you check the power on the jamma edge?
Uh, I don’t understand: shouldn’t the flashcart work within original carts specs?That thing is a consolized Neo geo. Multi carts are more sensible to bad quality power.
