Hello everyone!
In this thread you'll find all the information related to the first multi that converts your AES into a multi Slot system.
The principle is the same as with MVS. 3 ALL-Ram slots, MicroSD and menu based system.
LATEST LINKS
--> LATEST INSTRUCTIONS : September 25th 2024 <--
https://www.mediafire.com/file/exr7nsuny0an38h/Neo+Geo+-+Multi+MVS+++AES+-+Guide+v2.3.pdf/file
--> LASTEST FIRMWARE : May 30th 2020 <--
http://www.mediafire.com/file/52kjxy4bzoujxvn/20200530_r1169_AES_Only.7z/file
PLEASE NOTICE THAT THERE FIRMWARE FILES ARE DIFFERENT BETWEEN MVS AND AES VERSION. DON'T INSTALL THE WRONG ONE.
--> LATEST MENU: March 22nd 2023 <--
https://www.mediafire.com/file/t8rgbxra23lpyov/menu_20230322.7z/file
IMPORTANT!!!
To update the menu with latest version, you just need to copy the menu files in \update\menu.
Please make sure that you follow this procedure:
MENU UPDATE PROCESS:
* Extract microsd and copy the new menu files in the /update/menu folder
* Insert cartridge with microSD with new menu in your MVS and wait for it to update and reset (about 30 secs and screen can go black or show glitches. Don't worry.)
MENU
New Menu Features
* Artemio's Test Suite v095 (folder tstsuite)
* Xevious Homebrew (folder xevious)
* Someone had problems in the past with Data East games going back to the menu. This should be fixed from now on.
Menu is the same for both AES and MVS cartridges. Enjoy!
OLDER MENU (17th December 2021) https://www.mediafire.com/file/v2fjyyugh9cpn80/menu_20211217.7z/file
PREVIOUS LATEST MENU(UPDATED November 22th): http://www.mediafire.com/file/wamuwitsv96hhdt/menu_20191122.7z/file
PREVIOUS MENU April 1st (Needs FW 1040 or lower, available in the attachmen of this post): https://mega.nz/#!Vow1QapY!BDwTV-eK2_-qpQK8F-7L2hxYkKUJsiyCr5Dqqi9Ewp8
FIRMWARE
PLEASE NOTICE THAT THE FIRMWARE FILES ARE DIFFERENT BETWEEN MVS AND AES VERSION.
CURRENT FIRMWARE (May 30th, 2020): http://www.mediafire.com/file/52kjxy4bzoujxvn/20200530_r1169_AES_Only.7z/file
PREVIOUS FIRMWARE r1110 (November 18th, 2019): http://www.mediafire.com/file/wsask82w8y2yec0/20191118_r1110.zip/file
PREVIOUS FIRMWARE r996 (December 14th, 201
: http://www.mediafire.com/file/lozl6pyf0piqohs/20181204_r996.zip/file
FEATURES
It's coming AES multi - PREORDERS OPEN!!!
Thanks!
MICROSD SLOT:
the one that I'm using is this exact model and make: ATTEND 112J-TDAR-R01
It's made by taiwanese company ATTEND. You can buy it for example from these distributors:
https://www.soselectronic.com/products/attend/112j-tdar-r01-136625
https://www.tme.eu/es/details/mcc-sdmicro_3/conectores-de-tarjetas/attend/112j-tdar-r01/
https://www.top-electronics.com/en/micro-sd-socket-push-push-type
LATEST LINKS
IMPORTANT!!!
MENU
New Menu Features
FIRMWARE
FEATURES
- Fix BUFF opening and closing. Possibly also fixes other related to SD card issues.Fix new type of code injection breaking handling after clearFix routine.
- Fix vblank/USER subroutine injection: two ways of breaking injection: by last or first instruction hit.
- Turn off JSR injection module when return to Menu detected. Bug introduced long time ago. Gets activated by latest changes.
- Fix clear injection minimized
- Changes to ARM and FPGA. No FPGA backward compatibility preserved.
- Improved loading speed.
- Fixed GFX glitches on some AES models.
- Removed double reset
- Fixed wrong region in some games
- Fixed another bug when updating several slots concurrently.
- Removed Sound fading problems.
- Added support for monitor test tool. The tool must be placed in the folder "montest"
- Loading DDR of games and menu only when we exit menu, so we avoid loading a game into a SLOT that we may later change.
- No more DEAD REDLOCK Screen.
- Garbage when loading a new firmware or menu in AES fixed.
- BUFF File is automatically deleted after every menu update.
- Only 4 tunes haven been always available, although the menu showed more. This is now fixed and only those can be selected.
Thanks!
MICROSD SLOT:
