new Firmware is very good.1st post updated with latest firmware! Please update. This should fix all knnown issues, specially some random hangs when switching slots.
It has date of 27th July which is when it was released to testers.
Did it solve your issues?new Firmware is very good.1st post updated with latest firmware! Please update. This should fix all knnown issues, specially some random hangs when switching slots.
I'm still not able to switch between MVS and AES (using an original bios) is that normal?* Properly change Region and Mode (MVS/AES).
I might be wrong, but it is my understanding that the last firmware actually implements the function, but there’s no new menu yet which will implement the user interface in order to activate the function.I remember that too but reading the changelog I thought that something was change.
Not a big problem anyway
Because the instructions say "Just copy in \update\menu"Why did you put the file in a folder called menu?? It should be in the folder called update.
Now probably the menu is corrupted and that's why you see the pattern. Try updating the menu again and then the flash.img and let us know how it goes.
Not sure where the text you're quoting is from, I did a search for it and don't see it.
