ah really? Does it work fine if i update both simultaneously?You can simultaneously update the Firmware and the Menu. Put Firmware into update folder (2 files) and Menu into update/menu folder (5 files) Power on, should take about 30 secs to update
Check 'Version' should read
Firmware version: 0x44E
Firmware Build: 0xa160
Top File Build: 0x35bb
Menu version: Oct 18 2019.
Everything is looking good for my previously-troublesome MV1C and Unibios 3.3. No red screen on KOF98, Pulstar, or MS3. (I'm also not getting that weird write-address error anymore on KOF98, though that really was probably a bad pin contact on my MVS).for MVS all issues including the REDSCREEN should be fixed now.
I've never had any problem updating the firmware and menu simultaneously. I've even tried to break the cart on purpose but it's always recoverable if you eventually get it right.ah really? Does it work fine if i update both simultaneously?
Cool, I've updated my post to reflect thisYou can simultaneously update the Firmware and the Menu. Put Firmware into update folder (2 files) and Menu into update/menu folder (5 files) Power on, should take about 30 secs to update
, but I still have a red screen on kof98.That's right. It's 8th October.I just updated as well and also have a menu date of October 8th instead of 18. Think it's a mistake. Just tested KOF98 and it works fine for me. Using a 1FZ and Unibios 4.0.
