I seriously need to stop reading the forum on my mobile.See #74Dumb question but I just saw the updated FW but there's a line through it.
It has a little glitch so it was pulled.
I also do that and it's terrible, because I feel I can't reply properly with all the icons and quotes that I want to add, so I keep remembering all the time, that I need to answer this or that post as soon as I get back home. Maybe a function to mark again as unread a post would be nice....I seriously need to stop reading the forum on my mobile.
Just tested it in all the slots and it works fine for me. Using the Rollup Pack and testing on a mv1b (With Unibios 3.0)Last Blade 2 still doesn't reach character select for me.
Played some other games in slots 2/3 with no problems (Metal Slug X and Strikers 1945)
Well... Just tested Aero Fighters 2 and it plays with no problems.... had it running for like 5 minutes in the loop and then played it past second boss. No problems.Last Blade 2 seems ok on MVS Mode.
Aero Fighter 2 -> Not fixed, still Exception Error Handling, illegal instruction, adress : 00033888 (everytimes when starting the intro of the game, it's unplayable).
NvRAM already resetted and BUFF file deleted.
So it's not working at all for the moment for Aero Fighter 2 (tested on Analogue CMVS 3.3 Unibios & Omega CMVS 3.3 Unibios).
Still the Neo geo logo glitched on first boot => can be fixed (However instead of putting 0x0004 as mentioned they put 0x0040 instead --quoted from Razoola )
Edit :
Also still bugs with High Score for 90% of games (not writen as solved in this release so i think it's normal).
Same as above 1st for all in High Score, 0 for every scores, glitched name and scores... High Score are still not usable.
I can't reproduce either of these errors.Edit: Finally worked after unassigning the Metal Slug games first. Now Aero Fighters 2 works fine, but Aero Fighters 3 crashes just after the Neo Geo logo startup (the in-game one).
I did not delete the BUF files, that should have been the problem.@aha2940 did you delete the BUFF file after the menu update? Is that the only game giving errors or happens with more? This looks to me like a problem with the microSD.
