Mrhide
Legendary
All right. This is "picture documentation" on the elusive 32 inch Nanao ms8-33k that the internet seems to have never seen.
(edit scratch that! it was in Irem's Maddona 33 (https://wiki.himuland.eu/Bornes/Irem/madonna_33 and it does say 33" (15/24 kHz) (Nanao MS8-33) ). It makes sense since IREM = NANAO at the time)
I have 2 of them, from a Konami Hang Pilot where they were used for MEDIUM resolution.
for future searches
NANAO HV board 05A00514E1 05T00959 NECKBOARD 5B00753 05U02057 PCB-DEF 05A00515E1-5T00960- adjustment board 05U02056 remote board 05B00752C1 Mitsubishi M79KKZ11X tube
it's a 3 board system with, looking from the back, the power supply on the left, the HV at the bottom and the DEF board on the right
"PCB-DEF" board (drives yoke vertical and horizontal, HOT = 2SC4288A, recommended replacement : FJL6920 )
Power supply board
Thanks to the manual from the MS2932, TP901 is the B+ test point and sure enough, they kept the same numbering here. I don't know if it should also be 110V.
The pot to change it is in VR90A blue with the white silicon goop on it, on the power supply board.
Without chancgng caps it measures 196v dc. (That pretty high?)
High Voltage board
which include 2 small boards, one being a DF PCB (dual focus) and the other a "video pcb" board which amplifies and drives the RGB to the neck board
neck board
for future searches
Power supply board
High Voltage board
neck board
ALWAYS check the connector!! I even joked about it in the beginning of my last debug session.
