No, these are not "simple memory chips", these are:At least MAME did not have .u14 or .u15 files so it is looking bad... I thought that perhaps these are some memory chips that cartridge writes but it seems that that is not the case. I can read the working one and it gives me file full of ones and zeroes, so at least I can dump that. Does that sound proper content of the dump, some sort of assembly binary? What are the odds that these would have identical roms and I could just get new empty PAL and write it with the dump of the other working chip? Is that completely unheard ofAre these PALs dumped and converted to Gal?
If these are protected and no one dumped them, you can throw it in the bin
I always used my Top3000 for 27c322 and i've never done anything else than put them on the socket and hit burn. Maybe an old software revision?VP598 is the entry-level programmer I recommend. It supports more EPROMs than the TOP3000 without adapter boards, and it can program 27C322 chips in one pass while the TOP3000 requires bank switching.? Or can some one with Bee Storm dump their files from these two PALs?
"PAL devices have arrays of transistor cells arranged in a "fixed-OR, programmable-AND" plane used to implement "sum-of-products" binary logic equations for each of the outputs in terms of the inputs and either synchronous or asynchronous feedback from the outputs"
They are basically programmed gates. You cannot "dump" them and copy them. Well technically you can dump them but the result is wrong and the equation is not correct.
If you really want to dump them you need to solve the equation, but i'm not going to technical details since is out of my knowledge. The only thing i know is that you can't, not in that easy way at least.
If mame did not have that, well, there's nothing you can do (however, mame never had these in the rom set, the only place you can find them is at jammaarcade.net, they are dumped, converted and working. And no, they don't have ddp2).
These are basically the "keys" to the pcb door and they've been going since many years to prevent people make bootleg (and conversion, for us).
I suggest you to take a look at PGM conversions, there might be something usefull in order to replace that pal.
