Want To Buy
TheDrunkenArcade
Riverview, FL
Looking to get a CP for a Dynamo (19" I believe) with SF II Layout - with graphics would be preferred.
https://drive.google.com/open?id=1-58NiikhYWRZT2xutlY1lN4Fn109Mmqr photos of the cab currently.. I want to make it a SF II but the cp's current layout is fubar and I dont think I can convert it..
Links to someone that does repos, or that can point me to someone that has a SF Dynamo CP laying about they want to sell..
Thanks in advance
I think you are looking for a Dynamo HS-5 corner cut (cab takes a 25" CRT).
Far as I'm aware all the HS-5's are corner cut style, beware the HS-1 however.
It looks very close (cab takes 19" CRT) but isn't wide enough, HS-1 also came in both regular/classic and corner cut styles.
Oh you have a perfectly fine panel, just do the classic arcade operator trick...
Have a piece of plexiglass cut the same size/shape of the panel top, use it as a barrier to block the old button holes.
You get the idea here (if you have honestly never seen this technique back in the day).
