XeD
I don't know if that's the behavior but what I do to cut off power to cabs is I have a power brick connected to a remote control plug and I just turn cabs on with remote when I want them to have powerWith regard to the AC power connection to the Egret II PSU, I tested to determine which of the two connections is hot and which is neutral. I tested this by plugging one of the multimeter test leads into a wall outlet ground. Then plugged the other lead into each line on the AC connector going into the PSU. Seems both are hot and I am wondering if that is ok connect to an alternate PSU (Peter Chou).
Additionally, looks like the switch that is just under the Egret II only shuts down the marquee light and the monitor. It does not cut off the AC line to the PSU. So as long as the cab is plugged into an AC outlet, looks like the PSU is always going to draw power. And if you have a PCB connected, the PSU will always power the PCB. Is that expected behavior for the Egret II?
You know what? That is a very excellent question.Is there a drop in replacement chassis for the Windy tube
This could be a great way to revive these tubes with broken chassis! MS293x series chassis are not "easy" to come by, but definitely not unobtainium.Arcade Otaku said:<p style="margin-top: 0.5em; margin-bottom: 0.5em; line-height: inherit; color: rgb(34, 34, 34); font-family: sans-serif; font-size: 14px;" >The MS2931 and MS2934 share the same tube and yoke, only the chassis differs. It is a Toshiba tube with less curvature than an MS9 but more than a 29e31s on the longer side (the horizontal side if in yoko orientation). The MS2930, MS2931, and MS2934 are all compatible with each other. The correct replacement chassis is a Wei Ya 3129b or Rodotron 666b.
<p style="margin-top: 0.5em; margin-bottom: 0.5em; line-height: inherit; color: rgb(34, 34, 34); font-family: sans-serif; font-size: 14px; background-color: rgb(255, 255, 255);">Known tubes:
Toshiba A68KJU96X / MS2932 : H :0.4 Ohms V:7 Ohms
Toshiba A68LBT696X / MS2931 : H :0.9 Ohms V :6.8 Ohms
Toshiba A68KZN696X / MS2930 : H :0.5 Ohms V:6.7 Ohms
what about windy2 psuI am offer the following for refund. Pm with your name along with refund in the subject. In the body add your PayPal. Sorry I don't have time to go through my history trying to match user and their PayPal. I should have kept track of that from the start.
Chassis = 160 this should cover repair if flyback is ok
Psu (E2) = 70 this should cover for generic psu and the adapter harness
As long as you don't turn them ON while cold/damp you should be fine as long as the garage you are storing them in is dry and moisture-freeWhat are some good tips for storing cabs in cold weather?
I mentioned this before, but I never got an answer. Searching on the internet has given me mixed opinions as well. We've been getting sub-zero temps out here, and my cabs will be stored in a garage. Has anyone had any problems/success?
this may sound silly but when I got my big red freighted here I got big bag versions of those little packets they put in products that you don't want moisture getting into like beef jerky for instance. They are quit big bags. Just put 1 to 2 in each cab if its prolonged storage. They are called Desiccant Bags.What are some good tips for storing cabs in cold weather?
Curious about this as well. Anyone have a link to a video/guide on using an LCR meter to measure a CRT yoke?Anyone able to explain to me how to measure inductance on the yoke connector? I'd mistaken it for impedance. Related because replacing the tube in the Windy for 8bit.
