Lowering the voltage after cutting the trace?????????@GameOver you have a mv1fs. Try lowering the power from 5.00V down to 4.7V that should fix all your problems.
Regards.
Locutus73
As I am not using just MVS on this cab, I am not sure it is a good option(?).@GameOver you have a mv1fs. Try lowering the power from 5.00V down to 4.7V that should fix all your problems.
+1Lowering the voltage after cutting the trace?????????@GameOver you have a mv1fs. Try lowering the power from 5.00V down to 4.7V that should fix all your problems.
Regards.
Locutus73
@GameOver did you cut the trace as per the instructions? There is no software fix.
I think he already confirmed he has the latest 02-04-2018 pack which includes the latest menu update and all mobo dips are set to OFF.@GameOver
You have:-
Mv1fs at 5volts ( with cart trace cut )
Official roll up pack!
Has it been updated since? Menu/firmware?
What are your mobo dips set at?
Any unibios? What settings AES/MVS etc?
If we can copy your setup 1/1 we can help.
Not dumb, valid point. I always check with a multimeter to be sure.sorry if its ad dumb question, but have you tested with a multimeter if the trace is really cut?
Just to be 100% sure...
I guess that several blows of cutter is enough...sorry if its ad dumb question, but have you tested with a multimeter if the trace is really cut?
.Let me know if never memory comes backSomeone else had this same problem. I can't remember how he fixed it. I don't think it was the multi that was the problem though. I think it was his setup.
no problem, i'm a chemistTo be clear I am not a professional into electronic stuff, be pedagogue please
- on my multimeter the function i used has a symbol that looks like the wifi symbol on a computer - now when there is a connection between both probes it should beep.
To be clear: I do not have controls JUST on FF3 and Garou. I do not have tested all games by lack of time but 50 at least works 100%!I lost controls as well in my setup when I used 6 in 1 and a jamma extension, the same setup worked when connected directly to the supergun.
It got it fixed temporary by lowering the voltage (before trace cut). Then eventually it got fixed when I switched the jamma extension to a better quality one (eventually I also did the trace cut mod).
You're right.I think that wasn't clear for @Darksoft
@GameOver
You have:-
I can test it even if the card ins't powered?no problem, i'm a chemistTo be clear I am not a professional into electronic stuff, be pedagogue please- on my multimeter the function i used has a symbol that looks like the wifi symbol on a computer - now when there is a connection between both probes it should beep.
put the probes on the blue dots and if it beeps the line is still working
