Want To Buy
Akraten
Nashville , TN
Hello I am looking for some Florescent bulbs for candy cabs .
FL20SD
I see these in japan but I am just looking for an easier way to purchase them in the states if possible.
thanks
You can grab ones that work just fine from Home Depot/Lowes/Ace Hardware. Take yours with you and match it up.
I have also used F20T10's but F20T12's seemed easier to find years back. No idea if that's changed. Only difference is tube diameter.
https://www.lowes.com/search?searchTerm=f20t12 fluorescent bulb
Technically it looks like the ones Rewrite linked are a fraction of an inch shorter, 600mm / 23.62in vs 24in. I do recall having to slightly widen the ends of the fixture but it did not require what I'd consider excessive force, the bulb is just very snug.
If you have a batteries+bulbs store, they will order you exactly what you want, but it won’t be cheap either. Came out to like $19 a bulb when I bought two.
