[FS] JAMMA extension harness
I feel silly, but I still can't get button 6 working.
I cut the trace on the bottom of the HAS 4.2 per the manual. Extension cable is plugged in correctly (gold dot on pcb side). Enabling/disabling button 6 on the extension PCB makes no difference.
Perhaps I did not cut deep or far enough? It's pretty deep. Where should I be checking continuity to confirn (just to ground)?
Alright, everything is fine on the HAS end as far as the DIP switches. JAMMA harness is oriented correctly.
"Where should I be checking continuity to confirn (just to ground)?"
Exactly, check if there is indeed no continuity.
On the extension end, P1B6 and P2B6 DIP switches should be set to off.
Try without the Splitfire.
Unfortunately, these won't be available next month. I will definitely re-stock, but there's no ETA for now. Apologies for the inconvenience.
Knew I should have ordered 2. Pairs very well with the irken labs JVS to Jamma board.
That's why I ordered it and also a quality product, when it is in stock don't hesitate to order it.
  • Like
Reactions: RGB
Any update on ETA for these yet? I was hoping to get one of yours due to the guaranteed interop with my HAS, but I may try one of crown arcade shop's extension harnesses for now if you have no production timeline.
  • Like
Reactions: RGB
