[FS] JAMMA extension harness
How much slimmer is it? Also, wow, you might be the ONLY person who's put one of Jasen's cases on a LE, bravo!
21.4mm, could be less if you use slimmer screws on top as well.
I had to design that printed plexi for LE, I think you may be right, everyone seemed to put turtles or simpsons in these cases. I also have a SEGA System 16B in one, I didn’t listen when it said it was a Konami case.. 🤣
Me too I would love to get the
JAMMA Extension Harness by #HAS @RGB
If by any chance they will be available in the near future
Thanks in advance
PS : I added my email to be notified
  • Like
Reactions: RGB
Hey RGB, while you're here would this screen issue be cause by my meh cable, and if it is would you recommend a good one? Using the scart adapter and some monoprice 8pin din cable. Also, if it's an issue I'll delete the post.
That's an HSync issue, not a cable, but it's strange the RetroTink is giving you that with the CPS-3. Can you try some other display? Also, try the Raw CSync option, just in case (enable it in the Video Menu in the HAS). Please post a follow-up in the main HAS thread or via PM.
