ChuChu Flamingo
@RGB
I seem to have a problem on my HAS jamma extender now with super turbo.
If I press P1B6 on the extender to the on position it keeps being triggered. It will go through the title screen like a button is being held down even without a controller plugged it. Going to the test menu also shows it is being triggered. Additionally if I hold the joystick up or down it goes extremely fast in the menu.
Putting it to the off position and connect the cps2 kick harness directly to the cps2 button 6 works fine.
Did the dip switch die? Any solution for this? I barely used the jamma extender.
EDIT: Do I have to disable buttons 5/6 on the has main unit itself? Or the jamma extender. This is to get button 6 HK to work. I mean it was working before enabling button 6 on the extender+kick harness attached to it. I just disabled button 6 on jamma extender and enabled button 6 on the has main unit and all is fine. Just curious why it did work before the other way.
