I received my extension harness today and it’s working well. I readjusted my psu to get 5v on the game pcb jamma edge. Should I be concerned if the HAS itself is reading above 5v?
I get many questions about the CPS2 input. It isn't necessary, even if you don't own a HAS. However, if you want to use the HAS dedicated kick harnesses which connect to the other end of the JAMMA extension harness, then you'll need a way to connect buttons 4-6 (or perhaps just "6", depends on the supergun) to the JAMMA extension harness input - the CPS2 connector is basically for that. Below is a diagram that should be clearer than my words:
