Barth0lin0
Hey!
due to the difficulty to get a Jammaizer a few months ago, i tried to find a DIY solution to get my consoles hooked up to my Sega Blast City Candy cab. I already had a GBS-control on hand so i added a Scart input and tried pluging my console to it.
I was sure this would not work. I know arcade monitor need TTL level signal to work, right ?
A miracle happened , perfect Sega Genesis, perfect PS1, perfect Dreamcast 15 khz video signal. I was shocked! I can know play MUSHA on my cab! Life is good
Issue came when connecting the best console ever made : the Sega Saturn. I only get a super dark image. Sync is ok but the image is near black...i can barely see the Battle Garrega logo.
So, is there something different with the Saturn signal ? Does the GBS-C have a built-in RGB amp ? Is my monitor so special that it can handle some non TTL spec signal....but not the Saturn ?
Every console is wired the same way: RGC RGB scart cable to GBS-Control, VGA 15 kHZ output to VGA port of the Nanao 2931.
Should i solder an external RGB amp only for the Saturn ?
thx a lot guys!
thx a lot guys!
