I'm far from an expert, but I just recently did mine.
I purchased
@Arthrimus '
QSB for key writing. It's an extra expense, but it makes the install so much cleaner. I have zero issue with soldering to the pads, but this makes it a much nicer install.
I already had a phoenixed b board, so there was no issue for me "sacrificing" the board. Some might have an issue with "killing" the board, but the sacrifice you make vs the benefit you get.. It's a no brainier for me.
I originally thought the normal cable would be fine as I went with the mentality of "I'll just change games near the game board, but I've purchased a longer cable (and is still in transit) to allow me to install near the coin door or possibly even in the cp. Still to be decided.
I'd probably recommend getting the lcd case too. It just makes it so much easier to handle without having to worry about an exposed pcb.
Once the key writing qsb is installed, the rest of the install was pretty breezy since I had a rev 7 board and already had a pal g. Steps I too were:
- Downloaded @SmokeMonster 's base roll up pack
- Copied the contents to a Micro SD card (you might want to purchase the micro sd card too from whichever retailer you go as I had 4 attempts to find an sd card it would be able to read - seems to not like anything more than 8gb)
- Uninstalled the eproms
- Checked my jumpers with a multimeter
- Installed the smaller pcb very carefully (make sure orientation is correct), once I could see all the pins lined up, I gave it a good press to secure the board
- Installed the larger pcb very carefully, once I could see all the pins lined up, I gave it a good press to secure the board
- Installed the bridging pcb very carefully (make sure orientation is correct)
- Installed the lcd cable
- Turned the cab on and hoped for the best
(it took me 4 attempts since the msg I got was there's no sd card to read or somethingonv those lines, once I got that sorted, it was essentially choose and select)
- Cut/snap the stand-off on the b board case as pictured in the instructions.
One thing to note, the lcd contrast may be too much making the lcd extremely difficult to read unless you place it on a particular angle. If you do find this to be the case, before closing the board up, you can find a little potentiometer on the larger pcb which allows you to adjust the lcd contrast.
I was lucky enough with my install because my only issue was simply a micro sd card, once that was sorted, games boot fine.
If for some reason you're having issues, make sure you check out
The Definitive Guide to Fixing Your CPS2 Multi Kit thread.
