The Spaniard
With key writing is this forced to be on by default and done every time with the newest FW and the wires being installed?
Everything should be hereMaybe I missed it, but what exactly is key writing and why is it desirable?
Thanks!
Plays the games as if they were in their original-on-battery state; not decrypted as in the case with Avalaunch roms or hacked as in the case with Phoenix roms. The CPS2 multi writes the decryption keys upon bootup to achieve this.Maybe I missed it, but what exactly is key writing and why is it desirable?
Thanks!
So basically it's about as original as you can get?Plays the games as if they were in their original-on-battery state; not decrypted as in the case with Avalaunch roms or hacked as in the case with Phoenix roms. The CPS2 multi writes the decryption keys upon bootup to achieve this.Maybe I missed it, but what exactly is key writing and why is it desirable?
Thanks!
It's even better than that, remember the instructions that Eduardo Cruz posted about how to build the Arduino device needed to ressurect a dead CPS2 board? Well, you can skip that and just use Darksoft's multi to restore your board to OG state.So basically it's about as original as you can get?Plays the games as if they were in their original-on-battery state; not decrypted as in the case with Avalaunch roms or hacked as in the case with Phoenix roms. The CPS2 multi writes the decryption keys upon bootup to achieve this.Maybe I missed it, but what exactly is key writing and why is it desirable?
Thanks!
Ah, ok.
And so even with the wires hooked up and the newest firmware installed there are no potential risks of doing any damage to any of the boards?If there is no file *.key in the directory chosen, then no keys will be written.
nope. If you installed everything properly there is no risk.And so even with the wires hooked up and the newest firmware installed there are no potential risks of doing any damage to any of the boards?If there is no file *.key in the directory chosen, then no keys will be written.
Hey Darksoft, do you mind testing this on one of your spare kits, just so we know for sure...Yes, but as Mitsu said, DON'T CONNECT THE 4 WIRES TO PROGRAM KEYS IF YOU HAVE THE OLD FIRMWARE AS YOU MAY FRY YOUR KIT.You can still downgrade your FW if you don't want to use key writing or can't get key writing to work with your pcb for some reason.
You first
What do you want tested?Hey Darksoft, do you mind testing this on one of your spare kits, just so we know for sure...Yes, but as Mitsu said, DON'T CONNECT THE 4 WIRES TO PROGRAM KEYS IF YOU HAVE THE OLD FIRMWARE AS YOU MAY FRY YOUR KIT.You can still downgrade your FW if you don't want to use key writing or can't get key writing to work with your pcb for some reason.
Old Firmware plus the 4 wires connected = fried kit.What do you want tested?Hey Darksoft, do you mind testing this on one of your spare kits, just so we know for sure...Yes, but as Mitsu said, DON'T CONNECT THE 4 WIRES TO PROGRAM KEYS IF YOU HAVE THE OLD FIRMWARE AS YOU MAY FRY YOUR KIT.You can still downgrade your FW if you don't want to use key writing or can't get key writing to work with your pcb for some reason.![]()
Thanks! I will leave mine as is...no sense in messing with something that works great, if im not gonna do any of the stuff allowed in the upgrade.It basically can write the keys to the encryption on the game board as if it was original from factory.
Also good for de-suiciding boards.
i do not get it too.Thanks! I will leave mine as is...no sense in messing with something that works great, if im not gonna do any of the stuff allowed in the upgrade.It basically can write the keys to the encryption on the game board as if it was original from factory.
