GeorgeSpinner
Looks great!
Which EPROMs are you using C and V ROMs?
It looks like 27c160. It's hard to tell though.
What are you using for the P, M and S ROMs?
Thanks.
Looks great!
27c160 as C & VLooks great!
Thanks.
You can split the c-roms and use 4x 27c800 instead if you don't have enough 27c160s (my case).27c160 as C & V
27c800 as P or double it and use 27c160
27c1001 as M1
and 27c1000 as S1
you can use 27c1001 also on S1 but you have to invert pin 2 and pin 24
Thanks.You can split the c-roms and use 4x 27c800 instead if you don't have enough 27c160s (my case).
C1 becomes C1 and C3, and C2 becomes C2 and C4.
Altered Beast!?!?!? The NeoGeo already has a ton of shitty games!
It has a soft spot in my heart as well, but man, it's not a good one!
Dynamite Dux would be interesting though.
I still think Fantasy Zone 2 from the S16c board would be the most interesting b/c of the expanded RAM situation.
Looks great!
Thanks.
If you're in two player mode, you can wait for the timer to run out and start a fresh game with a different character.I don't think you can change characters when you continue in Golden Axe.
If you can, I will be surprised that I never noticed this in hundreds of sessions.
100% ASM and no, I'm not releasing the source code.coded in C or assembler? source code avallable?
Sorry if this is a double reply.Hey @h0ffman excellent port again and thanks a lot and whole team. I just saved on the Neo Geo CD.
2 things happen with me and I think is my console because I never updated the unibios.
- during continue, not able to select different characters.
- player 2 not playable just start is working. None the other buttons or direction is working.
Graphic and sound perfect
Just a little lagging when you finish the final boss and the queen and the king are being pulling down.
The rest perfectly
Thanks
Whatever you decide will be respected.100% ASM and no, I'm not releasing the source code.
Nope and I won't even entertain the idea. The fun part of this process is digging through the original game code and data and unearthing it's structure. It's like digital archeology.Hoffman, Have you experimented with Generative AI (like Anthropic Claude 3.5 Sonnet) tools to aid in the process?
The archeology part was what kept me hooked on the Midway stuff as well. There was lots of stuff disabled, debug, many comments too.Nope and I won't even entertain the idea. The fun part of this process is digging through the original game code and data and unearthing it's structure. It's like digital archeology.
;Fix!!!
; LOCKUP
move @bbshatter,a0 ;Already happened
jrnz #noshat2
; jruc #noshat2 ;THE NBA SUCKS!
Come on Mr. DJ, one more spin of that record....!Q: Will you please consider porting [insert game here]
A: Like all good DJs, I don't take requests
yes swap pin, disable check id and its work fineI'm planning to make a Golden Axe cart, I konw that I can use 27c010 for S1 instead of 27c1000, but now I got some 27c1000 and would like to use it in S1 but my programmer doesn't flash 27c1000, it's a TL866CS.
If I swap the pins in 27C1000 could I flash it as a 27C010?
Should I disable check ID option or there is an ic that I could select to flash it
PT-1210? For no reason.Q: Will you please consider porting [insert game here]
